Requires: IP-Symcon >= 5.3
array ZC_QueryServiceTypes (integer $InstanceID)
InstanceID | ID of the DNS-SD control to be requested |
Returns all services and information as an array. |
Queries the services of the DNS-SD control with the ID InstanceID and returns this as an array.
// Request the registered services of the DNS-SD Control with the ID 12345 ZC_QueryServiceTypes(12345); // Sample output /* Array ( [0] => Array ( [Name] => _afpovertcp [Type] => _tcp.local. [Domain] => . ) [1] => Array ( [Name] => _airplay [Type] => _tcp.local. [Domain] => . ) [2] => Array ( [Name] => _airtame [Type] => _tcp.local. [Domain] => . ) [3] => Array ( [Name] => _apple-mobdev2 [Type] => _tcp.local. [Domain] => . ) [4] => Array ( [Name] => _axis-video [Type] => _tcp.local. [Domain] => . ) ) */
