What can we improve?
Translation is in progress...
Not all topics are available at the moment and content links may be broken.
DMX Lighting
DMX (lighting) or also known as DMX512 is a digital protocol that is used in the stage and event technology. It is used to control dimmers, spotlights and other effects in discotheques. The acronym DMX stands for digital multiplex and it is a standard that has been standardized by DIN 56930-2. The connection to IP Symcon takes place via a DMX interface (about € 70). Devices such as e.g. a dimmer pack with a power output of 5 A per channel or RGB floodlights cost around € 100, -
IP-Symcon supports only the DMX4all USB gateway.
Deutsche Webseite verfügbar
Go to cart
