What can we improve?
(Edit)
DNS-SD Control
The DNS-SD control module manages established Bonjour services.
For further information one can search for Zeroconf or mDNS.
Installation
The DNS-SD Control is automatically installed as a core instance. This can be found in the object tree under core instances.
Configuration
New services (list element) can be added via the configuration page of the DNS-SD Control.
configuration page
These need a Name, RegType and Port. Domain and Host are optional, as are values. These are saved as key -> value pairs.
The same Name and RegType may not be reused for different list elements.
List element
After successfully adding, the new RegType and Name can be found and used directly via a Bonjour browser.
Bonjour Browser
Deutsche Webseite verfügbar
Go to cart
