Sommer-/Winterzeitwechsel 2016
Irgendwie ist der Wechsel meinem System nicht bekommen. Es wurde ein Logfile von 720MB für 3.5 Stunden angelegt (üblich sind ca. 60MB/Tag). Normaler Verlauf bis 02:59:59, ab dann
Auszug
02:00:00 | 12647 | DEBUG   | ScriptEngine         | Executing Event 12647 ~ Sender: TimerEvent
02:00:00 | 00000 | MESSAGE | ScriptEngine         | Too many scripts at once. Dropping execution...
12647 ist der Timer des Moduls „Unwetterzentrale“
Zwischendurch mal
02:00:09 | 00000 | MESSAGE | ScriptEngine         | Too many scripts at once. Dropping execution...
02:00:09 | 16466 | MESSAGE | VariableManager      | [Zentral_Skripte\Unwetterzentrale\Unwetterzentrale\Regenwert] = 2646
02:00:09 | 12647 | DEBUG   | ScriptEngine         | Executed Event 12647 ~ Sender: TimerEvent
02:00:09 | 12647 | WARNING | ScriptEngine         | Result for Event 12647
<br />
<b>Warning</b>:  imagecreatefrompng(): gd-png:  fatal libpng error: IDAT: CRC error in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>:  imagecreatefrompng(): gd-png error: setjmp returns error condition in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>:  imagecreatefrompng(): '/var/lib/symcon/media/radar42839.png' is not a valid PNG file in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>96</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>99</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>100</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>101</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>102</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>103</b><br />
<br />
<b>Warning</b>:  imagecolorresolve() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>104</b><br />
<br />
<b>Warning</b>:  imagecolorat() expects parameter 1 to be resource, boolean given in <b>/var/lib/symcon/modules/SymconMisc/Unwetterzentrale/module.php</b> on line <b>110</b><br />
<br />
Seit dem Neustart nach 03:00 ist alles wieder normal. Was läuft da schief? Hab ich was übersehen, was hätte geändert werden müssen?
Danke schon mal für Hilfe
Bruno
…auch bei mir hat die 4.1 testing den Zeitwechsel nicht überstanden…
Bei der 4.0 lief alles weiter…
Joachim
Ist hier auch so gewesen,mit der 4.1.
02:59:58 | 32279 | DEBUG   | VariableManager      | [LCN-Module\156 Teich\Ausgang 2 (0, 156)\Intensität] = 100
02:59:58 | 43353 | DEBUG   | VariableManager      | [LCN-Module\084-K.Schrank\Values (0, 84)\Temperatur Dallas Schrank A7] = 17,1
02:00:00 | 39636 | MESSAGE | VariableManager      | [WG Kai\IT-Geräte\Strato vServer\Host - Zuletzt online] = 1477789200
02:00:00 | 00000 | MESSAGE | ScriptEngine         | Zu viele gleichzeitige Skripte. Verwerfe Ausführung...
Um 3:00Uhr (auf 2:00Uhr) die Rückstellung der Zeit…
IPS lebte dann noch 15min und hat sich beendet.
Durch meinen watchdog wurde IPS auf dem Pi um 2:15 WINTERZEIT wieder gestartet, und läuft bis jetzt wieder rund.:smiley:
Bei mir genau das gleiche, aufgewacht ohne Licht und die Rollläden blieben geschlossen. Leider habe ich keinen Watchdog.
Wie hast Du denn den Watchdog implementiert? Ich würde gerne solche Situationen in Zukunft vermeiden…
So wie ich sehe, hat es bisher nur die Pi Version zum Absturz gebracht, oder?
Ich glaube es gibt insgesamt zwei Probleme zu lösen:
a) Warum führt IP-Symcon beim Zeitsprung Skripte, die genau um 02:00:00 starten, mehrfach aus?
b) Warum greift das „Verwerfe Ausführung…“ korrekt, aber IP-Symcon stürzt (auf Pi) ab.
Mein d
pi + ips 4 ist auch durchgelaufen. Meiner hat auf Basis der astrofunktion die Jalousien passend geöffnet und läuft brav vor sich hin… Ohne absturz :slight_smile:
4.1 Testing hier auch durcheinander
Guten Morgen Zusammen,
also meine Symbox mit der 4.1 testing hat die Zeitumstellung ohne Probleme überstanden. (Ich gebe zu ich in verwundert :smiley: )
Ich konnte im Log keine Probleme feststellen. Und auch sonst läuft alles wie es soll!
Mirank
Guten Morgen,
auch meine 4.1 Testing hat den Wechsel überstanden…
Gruss aus EU,
Jörg
Meine Symbox mit 4.0 stable ist abgestürzt.
Lördy
meine 4.1 Testing läuft noch. Das Logfile ist allerdings ca. 550MB groß sonst max. 73MB.
Gruß Christian
…das ist hier ist vielleicht der entscheidende Teil:
02:59:45 | 18349 | DEBUG   | ScriptEngine         | Skript ausgeführt - Ereignis: 27411 ~ Absender: TimerEvent
02:59:50 | 37602 | DEBUG   | ScriptEngine         | Skriptausführung - Ereignis: 53782 ~ Absender: TimerEvent
02:59:50 | 11192 | DEBUG   | VariableManager      | [Raspberry Pi\CPU-Temperatur] = 53
02:59:50 | 44300 | DEBUG   | VariableManager      | [Raspberry Pi\CPU-Auslastung] = 16,6
02:59:50 | 31408 | DEBUG   | VariableManager      | [Raspberry Pi\CPU-Spannung] = 1,35
02:59:50 | 57358 | DEBUG   | VariableManager      | [Raspberry Pi\CPU-Frequenz] = 1000
02:59:50 | 40408 | DEBUG   | VariableManager      | [Raspberry Pi\GPU-Temperatur] = 53
02:59:50 | 37602 | DEBUG   | ScriptEngine         | Skript ausgeführt - Ereignis: 53782 ~ Absender: TimerEvent
02:00:00 | 18954 | DEBUG   | ScriptEngine         | Skriptausführung - Ereignis: 11222 ~ Absender: TimerEvent
02:00:01 | 00000 | MESSAGE | ScriptEngine         | Zu viele gleichzeitige Skripte. Verwerfe Ausführung...
…danach geht es dann bis 3:51 Uhr so weiter…
Joachim
Hallo.
Auch bei mir (Pi3, Testing V4.1) beim Sprung von 2:59:59 auf 2:00:00 (Winterzeit) das total Chaos.
Siehe Vorredner.
Aber ab 3:00:00 beruhigt es sich schlagartig. KEIN ABSTURZ Ich denke es sind die Timer und Ereignisse, die da mit der rückversetzten Zeit nicht mehr klargekommen sind.
Schönes WE
lueralba
Mein System IPS4.0 auf Rpi ist heute Nacht auch abgestürzt.
na da bin ich ja froh das ich nach wie vor IPS auf Windwos laufen habe :slight_smile:
Hier läuft alles …
Grüsse
Thomas
Hm, hier läuft es zwar noch (Raspberry IPS 4.0 stable) aber das Logfile von heute ist ebenfalls über 500MB groß…
Ja, auch bei mir alles ohne Probleme überstanden.
Mal gerade reingeschaut, ist genau in dem Moment wo er von 03:00 Uhr wieder auf 02:00 Uhr springt:
02:59:32 | 10564 | MESSAGE | VariableManager      | [Messen-Überwachen-Melden\Umwelt-Sensoren\Wettersensor KS300\Wettersensor\Temperatur] = 5,2
02:59:32 | 11351 | MESSAGE | VariableManager      | [Messen-Überwachen-Melden\Umwelt-Sensoren\Wettersensor KS300\Wettersensor\Luftfeuchtigkeit] = 85
02:59:52 | 19949 | MESSAGE | VariableManager      | [Messen-Überwachen-Melden\AKM\Tracker ***\Update] = 1477789192
02:00:00 | 11298 | MESSAGE | VariableManager      | [Messen-Überwachen-Melden\AKM\Tracker ***\Update] = 1477789200
Die nun folgende Fehlermeldung wird etwa 1452 mal pro Sekunde ausgegeben :eek:
Um 03:00 Uhr ist dann vorbei mit dem Spuk! In der Stunde wurden genau 5.174.984 Zeilen geschrieben…uuups.:eek::eek:
Wie gut das ich mein Log aufs NAS ausgelagert habe, das hätte bestimmt nicht jede Speicherkarte mit gemacht.
Vielleicht kommt ja daher auch der Systemabsturz bei anderen!?
Bei mir ohne Absturz durchgelaufen
Nachtrag:
Habe gerade bemerkt, das meine Heizung nicht mehr abgefragt wird !
-> Die Registervariable des ClientSocket meines Exsys6034 reicht nicht mehr an das Script durch !!!
Alle Versuche es wieder zum laufen zu bekommen scheitern.
Erst ein Neustart hilft…
lueralba
