Fix multiply serial USB ports (ttyUSB) on a RPi with a symlink
Hello All,
I have the following configuration:
  • USB > RS-485 to communicate with my „climate“ modbus
  • USB > RS-485 to communicate with my „outdoor lights“ modbus
  • Z-wave stick
I’ve got it all working but when I reboot my pi I sometimes have to change the SerialPort Port setting…
I tried to follow this PersistentUSBDevices - Domoticz (sorry I used domoticz in the past) tutorial but for some reason I cannot select the new created symlink in IP-symcon. And if I set it using the IPS_SetProperty function. It sais the Value is not available.
I hope one of you can help me out.
Hi, many here in this Forum have the same problem and no one have a fix. The symcon team unfortunately does not fix the annoying problem.
Maybe there is a way to make a workaround with a script???
Thank you for you reply! I have no clue how to do this with a script, do you have an example for me?
Ok, I think I fixed it! Maybe good a work around for the rest who are looking for this solution. Here my tutorial:
Step 1:
In this step we are going to find the information to identify our USB serial device.
Using putty or your favorite ssh client, run:
sudo lsusb -v | more
find and note these values for each of your device:
*idVendor (without „0x“)
*idProduct (without „0x“)
*iSerial (if this is zero, you can ignore it)
I found these values for my RS485 converter:
idVendor: 0403
idProduct: 6001
iSerial: A9U95FZF
Step 2:
In this step we are going to create a rule for the udev to make a symlink. I wanted the name symlink ttyUSB-MBclima so I can easily remember and recognize it. Of course you can enter your own name
Run:
sudo nano /etc/udev/rules.d/99-usb-serial.rules
Add the following line with the values for each device you found:
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A9U95FZF", SYMLINK+="ttyUSB-MBclima"
Step 3:
Now we are going to restart your device and check if the symlinks are created:
Run:
cd /dev
ls -l
the last command will give you a list of all the files in this directory. look for something like this:
lrwxrwxrwx 1 root root           7 Mar  6 18:17 ttyUSB-MBclima -> ttyUSB0
this is your symlink.
Step 4:
Make the script:
Make a script and add this:
$rightTTYport = "/dev/".exec("readlink /dev/ttyUSB-MBclima");
IPS_SetProperty(50297 /*[MB_Clima]*/, "Port", $rightTTYport);
Change the following values to the right values as it is configured in your setup:
  • ttyUSB-MBclima (the name of the symlink you have created in step 2)
  • 50297 /[MB_Clima]/ (the objectID of used serial connection in „I/O instances“)
Step 5:
Run the script at startup of IP-symcon
Go to „Core Instances“ > „Events“ and add the created script to „Startup Script“ field.
That’s it! I tested it and it works like a charm!
Thanks, i will give it a try
Forgot to add IPS_ApplyChanges() to the script… Why can’t i change my messages
The script should look like this:
$ID = 50297 /*[MB_Clima]*/;
IPS_SetProperty($ID, "Port", $rightTTYport);
IPS_ApplyChanges($ID)
works realy great!! thanks a lot - was frustrated by loosing USB connection every reboot :wink:
you made my day !!
Sorry fürs hochziehen des alten Beitrags, aber Google findet diese Themen immer noch :slight_smile:
IP-Symcon 5.6 wird Symlinks auf /dev/ttyUSB* erkennen und ebenfalls unterstützten
