So hier mein erster Versuch und es geht, aber jetzt muss ich noch das Gegenteil programmieren, wenn ich ein Outpumodul haben will…
Hier das noch nicht fertige Script sind nur 3 Pins drin:
#!/usr/bin/python
# Copyright 2012 Daniel Berlin (with some changes by Adafruit Industries/Limor Fried)
# Permission is hereby granted, free of charge, to any person obtaining a copy of
# this software and associated documentation files (the "Software"), to deal MCP230XX_GPIO(1, 0xin
# the Software without restriction, including without limitation the rights to
# use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
# of the Software, and to permit persons to whom the Software is furnished to do
# so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
from Adafruit_I2C import Adafruit_I2C
import smbus
import time
import os
MCP23017_IODIRA = 0x00
MCP23017_IODIRB = 0x01
MCP23017_GPIOA = 0x12
MCP23017_GPIOB = 0x13
MCP23017_GPPUA = 0x0C
MCP23017_GPPUB = 0x0D
MCP23017_OLATA = 0x14
MCP23017_OLATB = 0x15
MCP23008_GPIOA = 0x09
MCP23008_GPPUA = 0x06
MCP23008_OLATA = 0x0A
class Adafruit_MCP230XX(object):
OUTPUT = 0
INPUT = 1
def __init__(self, address, num_gpios, busnum=-1):
assert num_gpios >= 0 and num_gpios <= 16, "Number of GPIOs must be between 0 and 16"
self.i2c = Adafruit_I2C(address=address, busnum=busnum)
self.address = address
self.num_gpios = num_gpios
# set defaults
if num_gpios <= 8:
self.i2c.write8(MCP23017_IODIRA, 0xFF) # all inputs on port A
self.direction = self.i2c.readU8(MCP23017_IODIRA)
self.i2c.write8(MCP23008_GPPUA, 0x00)
elif num_gpios > 8 and num_gpios <= 16:
self.i2c.write8(MCP23017_IODIRB, 0xFF) # all inputs on port B
self.direction |= self.i2c.readU8(MCP23017_IODIRB) << 8
self.i2c.write8(MCP23017_GPPUA, 0x00)
self.i2c.write8(MCP23017_GPPUB, 0x00)
def _changebit(self, bitmap, bit, value):
assert value == 1 or value == 0, "Value is %s must be 1 or 0" % value
if value == 0:
return bitmap & ~(1 << bit)
elif value == 1:
return bitmap | (1 << bit)
def _readandchangepin(self, port, pin, value, currvalue = None):
assert pin >= 0 and pin < self.num_gpios, "Pin number %s is invalid, only 0-%s are valid" % (pin, self.num_gpios)
#assert self.direction & (1 << pin) == 0, "Pin %s not set to output" % pin
if not currvalue:
currvalue = self.i2c.readU8(port)
newvalue = self._changebit(currvalue, pin, value)
self.i2c.write8(port, newvalue)
return newvalue
def pullup(self, pin, value):
if self.num_gpios <= 8:
return self._readandchangepin(MCP23008_GPPUA, pin, value)
if self.num_gpios <= 16:
lvalue = self._readandchangepin(MCP23017_GPPUA, pin, value)
if (pin < 8):
return
else:
return self._readandchangepin(MCP23017_GPPUB, pin-8, value) << 8
# Set pin to either input or output mode
def config(self, pin, mode):
self.direction = self._readandchangepin(MCP23017_IODIRA, pin, mode)
if (pin < 8):
else:
self.direction |= self._readandchangepin(MCP23017_IODIRB, pin-8, mode) << 8
return self.direction
def output(self, pin, value):
# assert self.direction & (1 << pin) == 0, "Pin %s not set to output" % pin
self.outputvalue = self._readandchangepin(MCP23008_GPIOA, pin, value, self.i2c.readU8(MCP23008_OLATA))
if (pin < 8):
self.outputvalue = self._readandchangepin(MCP23017_GPIOA, pin, value, self.i2c.readU8(MCP23017_OLATA))
else:
self.outputvalue = self._readandchangepin(MCP23017_GPIOB, pin-8, value, self.i2c.readU8(MCP23017_OLATB)) << 8
return self.outputvalue
self.outputvalue = self._readandchangepin(MCP23017_IODIRA, pin, value, self.outputvalue)
def input(self, pin):
assert self.direction & (1 << pin) != 0, "Pin %s not set to input" % pin
value = self.i2c.readU8(MCP23008_GPIOA)
elif self.num_gpios > 8 and self.num_gpios <= 16:
value = self.i2c.readU8(MCP23017_GPIOA)
value |= self.i2c.readU8(MCP23017_GPIOB) << 8
return value & (1 << pin)
def readU8(self):
result = self.i2c.readU8(MCP23008_OLATA)
return(result)
def readS8(self):
if (result > 127): result -= 256
return result
def readU16(self):
assert self.num_gpios >= 16, "16bits required"
lo = self.i2c.readU8(MCP23017_OLATA)
hi = self.i2c.readU8(MCP23017_OLATB)
return((hi << 8) | lo)
def readS16(self):
if (hi > 127): hi -= 256
def write8(self, value):
self.i2c.write8(MCP23008_OLATA, value)
def write16(self, value):
self.i2c.write8(MCP23017_OLATA, value & 0xFF)
self.i2c.write8(MCP23017_OLATB, (value >> 8) & 0xFF)
# RPi.GPIO compatible interface for MCP23017 and MCP23008
class MCP230XX_GPIO(object):
OUT = 0
IN = 1
BCM = 0
BOARD = 0
def __init__(self, busnum, address, num_gpios):
self.chip = Adafruit_MCP230XX(address, num_gpios, busnum)
def setmode(self, mode):
# do nothing
pass
def setup(self, pin, mode):
self.chip.config(pin, mode)
return self.chip.input(pin)
self.chip.output(pin, value)
self.chip.pullup(pin, value)
if __name__ == '__main__':
# Set num_gpios to 8 for MCP23008 or 16 for MCP23017!
#mcp = Adafruit_MCP230XX(address = 0x20, num_gpios = 8) # MCP23008
mcp = Adafruit_MCP230XX(address = 0x20, num_gpios = 16) # MCP23017
# Set pins 0, 1 and 2 to output (you can set pins 0..15 this way)
mcp.config(0, mcp.OUTPUT)
mcp.config(1, mcp.OUTPUT)
mcp.config(2, mcp.OUTPUT)
# Set pin 3 to input with the pullup resistor enabled
mcp.config(7, mcp.INPUT)
mcp.pullup(7, 1)
mcp.config(6, mcp.INPUT)
mcp.pullup(6, 1)
mcp.config(5, mcp.INPUT)
mcp.pullup(5, 1)
# Read input pin and display the results
#print "Pin 7 = %d" % (mcp.input(7) >> 7)
pin7 = 0
pin6 = 1
pin5 = 1
test="%d" % (mcp.input(7) >> 7)
print test
# Python speed test on output 0 toggling at max speed
print "CTRL+C to quit"
#test="%d" % (mcp.input(7) >> 7)
#print mcp.input(6)
#print mcp.input(5)
while (True):
#print mcp.input(6)
#print mcp.input(5)
# mcp.output(0, 1) # Pin 0 High
#time.sleep(1);
#mcp.output(0, 0) # Pin 0 Low
#time.sleep(1);
#if test == 0 and pin7 ==0:
if mcp.input(7) == 0 and pin7 ==0:
print "pin7=low"
pin7=1
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t /device/gpio/7 -m "ON"')
#continue
#if test == 1 and pin7 ==0:
if mcp.input(7) == 128 and pin7 ==1:
print "pin7=high"
pin7=0
#continue
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t /device/gpio/7 -m "OFF"')
#PIN6
if mcp.input(6) == 64 and pin6 ==0:
print "pin6=low"
pin6=1
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t gpio -m "pin6=off"')
#continue
if mcp.input(6) == 0 and pin6 ==1:
print "pin6=high"
pin6=0
#continue
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t gpio -m "pin6=on"')
#PIN 5
if mcp.input(5) == 32 and pin5 ==0:
print "pin5=low"
pin5=1
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t gpio -m "pin5=off"')
#continue
if mcp.input(5) == 0 and pin5 ==1:
print "pin5=high"
pin5=0
#continue
os.system('mosquitto_pub -h 192.168.0.5 -u user -P password -t gpio -m "pin5=on"')
