Could not match ROM
Hello,
Unfortunately, after the upgrade to the last version - 4.4, Windows x64, 2018-02-19, 36a7b6fcaa27 my 1-wire network based on esera Bus Coupler Ethernet 11308 (two devices) stop working properly. On 1-wire configurator instance I have strange device id -FFFFFFFFFFFFFEA0 with name - 0xA0. I have also other 1-wire device (BT bridge)which working normaly.
Does anyone have a similar problem?
Regards,
Makki
Yes, have a look here: Problem mit 1 Wire nach umstihg auf version 4.4 # 2058
Do you know from which version you were upgrading?
I am 99% sure that one build earlier.
On OnewireViewer software I can see all devices corectly.
Makki
Here are download links for the older versions:
Can you please check which one is the first with the error? That would help a lot!
http://apt.symcon.de/pool/win/symcon_4.4-2058_amd64.exe (19.02)
http://apt.symcon.de/pool/win/symcon_4.4-2057_amd64.exe (19.01)
http://apt.symcon.de/pool/win/symcon_4.4-2056_amd64.exe (10.01)
http://apt.symcon.de/pool/win/symcon_4.4-2055_amd64.exe (08.01)
http://apt.symcon.de/pool/win/symcon_4.4-2054_amd64.exe (05.01)
http://apt.symcon.de/pool/win/symcon_4.4-2053_amd64.exe (16.12)
On all version I have the same problem.First I try to install older version on existing one. Then I try with clean install but problem still exist. OnewireViewer workig normaly. Is it possible that the last version changed something in the system?
Makki
Can you try those versions aswell? You do not need to uninstall. You install over the current version.
http://apt.symcon.de/pool/win/symcon_4.4-2052_amd64.exe (14.12)
http://apt.symcon.de/pool/win/symcon_4.4-2051_amd64.exe (14.12)
http://apt.symcon.de/pool/win/symcon_4.4-2050_amd64.exe (12.12)
http://apt.symcon.de/pool/win/symcon_4.4-2049_amd64.exe (06.12)
http://apt.symcon.de/pool/win/symcon_4.4-2048_amd64.exe (24.11)
http://apt.symcon.de/pool/win/symcon_4.4-2047_amd64.exe (18.11)
http://apt.symcon.de/pool/win/symcon_4.4-2046_amd64.exe (14.11)
http://apt.symcon.de/pool/win/symcon_4.4-2045_amd64.exe (10.11)
http://apt.symcon.de/pool/win/symcon_4.4-2044_amd64.exe (08.11)
Somewhere inbeween there must have been a regression :frowning:
Today I stopped ipsymcon service and rename main folder with my last 2058 installation. Then started with clean installation from 2044 version but 1-wire devices did not work properly. When I work with 2052 version I have restart computer 2 times and also unplug 1-wire controller from power and everything started working (I have made the same restart earlier with 2058 version but without success).
After that I deleted folder with 2052 version and rename folder with my final installation - 2058 version and everything working normally.
I have no logical explanation.
Makki
@Jimmyrakete: Konntest du das Problem vielleicht noch weiter eingrenzen?
