Hello,
I have integrated xComfort with symcon.
I have set up the dimmers to be controlled by sliders in the app on my iPad.
When i use the slider betveen 1% and 99% it seemes like everything is working correct.
But when i try to dim straight to 0% or 100% nothing happens.
The problem only occurs when i use the app on the iPad.
When i control the dimmers through WebFront on the webpage everything seemes to work.
Does anyone have the same problem, or have a solution?
It seems like I’ve operated the slider with „speed“ when I’ve tested on the iPad and not on the phone.
It seems that the problem occurs when you set the slider below or above the set point?..
Something that i believe could happen if you change the setpoints from 0% to 100% or 100% to 0% fast.
