lundig
1
Hello,
I have to start with informing that i am a newbie concidering IPS.
I am trying to setup lightscenarios with float variables.
When i use a constant variable with datatype float it works.
But when i use the float variable it don’t work
Any hints?
//Lundig
that seems to be a limitation in the current workflows.
You can solve it by adding a „Formula“ Module to your Workflow with the following Code:
$result = (int)$value1
I will check for a solution in one of the next Studio Versions
lundig
3
Thanks for the tip!
It worked
Lundig
