+ Antworten
Seite 45 von 55 ErsteErste ... 35 43 44 45 46 47 ... LetzteLetzte
Ergebnis 441 bis 450 von 545
  1. #441
    Registriert seit
    Dec 2009
    Ort
    Calw
    Beiträge
    338
    ich bekomme seit ein paar Tagen immer diese Fehlermeldung.
    PHP-Code:
    14.05.201916:09:50 FlowHandler Kann Daten nicht zur Instanz #47555 weiterleiten: <br /><b>Notice</b>:  Undefined index: indoortempf in <b>/var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php</b> on line <b>293</b><br /><br /><b>Notice</b>:  Undefined index: tempf in <b>/var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php</b> on line <b>295</b><br /><br /><b>Notice</b>:  Undefined index: dewptf in <b>/var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php</b> on line <b>297</b><br /><br /><b>Notice</b>:  Undefined index: windchillf in <b>/var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php</b> on line <b>299</b><br /><br /><b>Fatal error</b>:  Uncaught TypeError: Argument 1 passed to WeatherStation::FahrenheitToCelsius() must be of the type float, null given, called in /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php on line 302 and defined in /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php:177Stack trace:#0 /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php(302): WeatherStation-&gt;FahrenheitToCelsius(NULL)#1 /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php(274): WeatherStation-&gt;WriteData('POST /data/repo...')#2 /-(3): WeatherStation-&gt;ReceiveData('{&quot;DataID&quot;:&quot;{7A1...')#3 {main}  thrown in <b>/var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php</b> on line <b>177</b><br />Abort Processing during Fatal-Error: Uncaught TypeError: Argument 1 passed to WeatherStation::FahrenheitToCelsius() must be of the type float, null given, called in /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php on line 302 and defined in /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php:177Stack trace:#0 /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php(302): WeatherStation->FahrenheitToCelsius(NULL)#1 /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php(274): WeatherStation->WriteData('POST /data/repo...')#2 /-(3): WeatherStation->ReceiveData('{"DataID":"{7A1...')#3 {main}  thrown   Error in Script /var/lib/symcon/modules/IPSymconWeatherStation/WeatherStation/module.php on Line 177
    Kann jemand was damit anfangen?
    IPS V 5.3(Docker), ENO TCM 310 LAN-GW, KNX Installation, IPS-868, Pokeys57E, IPSView, IPS Z-Wave+ LAN GW, HUE, Google Home, mqtt ESP
  2. #442
    Registriert seit
    Mar 2008
    Ort
    Ruesselsheim
    Beiträge
    3,755
    Zitat Zitat von Fonzo Beitrag anzeigen
    Hatt schon jemand von Euch mit der neuen Firmware 1.3.2 rumgespielt? Diese kann z.B. mit WS View hochgeladen werden. Es steht dann eine Custom Upload Funktion zur Verfügung, hier kann man einen Server eintragen, in dem Fall auch IP-Symcon.
    Hallo
    Mit der Version 1.3.2 kammen keine Daten bei mir an .
    Aber mit der neuen Version 1.3.7 kommen bei mir direkt die Daten von der Station
    Format sieht so aus :
    26.05.2019, 13:33:09 | RECEIVED [192.168.1.91:47000] | GET /weatherstation/updateweatherstation.php?ID=123456789012345678901& PASSWORD=123456789012345678901&indoortempf=78.6&te mpf=71.8&dewptf=48.7&windchillf=71.8&indoorhumidit y=43&humidity=44&windspeedmph=2.5&windgustmph=3.4& winddir=277&absbaromin=29.94&baromin=29.24&rainin= 0.00&dailyrainin=0.00&weeklyrainin=0.00&monthlyrai nin=2.17&solarradiation=741.72&UV=8&dateutc=2019-05-26%2011:33:08&softwaretype=EasyWeatherV1.3.7&actio n=updateraw&realtime=1&rtfreq=5 HTTP/1.0<CR><LF>Host: 192.168.1.10<CR><LF>Accept:*/*<CR><LF>Connection: Close<CR><LF><CR><LF>
    Geändert von 1007 (26.05.19 um 12:34 Uhr)
  3. #443
    Registriert seit
    Mar 2008
    Ort
    Ruesselsheim
    Beiträge
    3,755
    Mit der aktuellen Version der Firmware funktioniert das Modul auch, aber mir ist es nicht gelungen den Port umzustellen.
    Sendet immer an Port 80.
  4. #444
    Registriert seit
    Oct 2011
    Ort
    Hattersheim (Hessen)
    Beiträge
    7,011
    Werde ich dann mal ausprobieren und dann das Modul anpassen.
  5. #445
    Registriert seit
    Oct 2011
    Ort
    Beiträge
    7,011
    Ich konnte zumindest mal die aktuelle Firmware aufspielen. Aber ein Empfangen von Daten war mir bisher noch nicht möglich, da bei mir Port 80 belegt ist durch ein Webserver. Muss ich also wohl mal mit einem System probieren bei dem Port 80 verfügbar ist. Dies ist aber aus meiner Sicht ein Bug, wozu gibt man denn einen Port in den Einstellungen der Wetterdstation an, wenn da dieser dann nicht benutzt wird?
  6. #446
    Registriert seit
    Aug 2015
    Ort
    Stralsund
    Beiträge
    20
    PHP-Code:
    Jetzt muss man da nur noch was lesbares draus zaubern
    Gruß Robert
  7. #447
    Registriert seit
    Aug 2015
    Ort
    Stralsund
    Beiträge
    20
    Funktioniert
  8. #448
    Registriert seit
    Mar 2006
    Ort
    Oberfranken, Germany
    Beiträge
    812
    Hallo, ich wollte gerade nach dem ich deinen Betrag gelesen hatte, auf die Version 1.3.7 updaten. Es gibt jetzt schon die 1.3.8 Ob bei mir Daten ankommen kann ich leider erst heute Abend testen.
    VG
    Andreas
    Software: IPS V5.1 unl. 3406 Variablen Hardware:. Pi3 mit 120GB SSD Fritz!Box7590 Fritz!OS7.12 + 2 x Fritz!Box 7390 Fritz!OS6.83 | Fritz!Repeater |Sainlogic: 10 in 1 Fw1.4.0 | Pokeys57E | CCU2a (auf Pi3+HM-MOD-RPI-PCB PiVCCU mit 120GB SSD)+HMW-LGW-O-DR-GS-EU mit HM Conf.Tool LAN und CCU2b 2.35.16 (auf Pi3 mit HM-MOD-RPI-PCB PiVCCU mit 120GB SSD) mit 2 x HM Conf.Tool LANs l RFID-Zug.kontrollen
  9. #449
    Registriert seit
    Mar 2008
    Ort
    Ruesselsheim
    Beiträge
    3,755
    Hallo
    Mit der neuen Version 1.3.8 funktioniert die Zuweisung auch mit dem Port.
    Habs getestet.Bug ist behoben.
  10. #450
    Registriert seit
    Dec 2009
    Ort
    Calw
    Beiträge
    338
    Bei mir klappt es nun auch ohne Port umbiegen.
    Mit der neuen Firmware 1.3.8 kann man endlich an einen beliebigen Port senden.
    Daten kommen an und Modul funktioniert nach wie vor.
    Ich habe aktuell nur das Problem, das hin und wieder so alle paar Tage falsche Werte ankommen.
    Da kommen Werte an für z.B. außen Temp. mit -5572 °C.
    Hat jemand eine Idee woran das liegen könnte?
    Bzw. tritt das nur bei mir auf oder auch bei anderen?
    Auszug aus Log:
    PHP-Code:
    26.5.2019 18:25:00;19,6;26.5.2019 18:28:10;19,2;26.5.2019 18:25:00;20,0
    26.5.2019 18
    :20:00;20,0;26.5.2019 18:20:00;20,0;26.5.2019 18:20:00;20,0
    26.5.2019 18
    :15:00;-1881,5;26.5.2019 18:15:32;-5572,8;26.5.2019 18:15:00;20,0
    26.5.2019 18
    :10:00;20,0;26.5.2019 18:10:00;20,0;26.5.2019 18:10:00;20,0
    26.5.2019 18
    :05:00;20,0;26.5.2019 18:05:00;20,0;26.5.2019 18:05:00;20,0
    26.5.2019 18
    :00:00;-166,4;26.5.2019 18:00:00;-5572,8;26.5.2019 18:00:10;20,0
    26.5.2019 17
    :55:00;-5572,8;26.5.2019 17:55:00;-5572,8;26.5.2019 17:55:00;-5572,8
    26.5.2019 17
    :50:00;-4845,6;26.5.2019 17:50:39;-5572,8;26.5.2019 17:50:00;21,1
    26.5.2019 17
    :45:00;21,1;26.5.2019 17:45:00;21,1;26.5.2019 17:45:00;21,1
    26.5.2019 17
    :40:00;21,1;26.5.2019 17:40:00;21,1;26.5.2019 17:40:00;21,1
    26.5.2019 17
    :35:00;21,1;26.5.2019 17:35:00;20,8;26.5.2019 17:35:06;21,
Ähnliche Themen
  1. Antworten: 0
    Letzter Beitrag: 19.11.17, 19:24
  2. Schaltbefehle per Funk oder WLAN, brauche Hilfe!
    Von computerpap im Forum Bastel-Ecke
    Antworten: 9
    Letzter Beitrag: 19.07.17, 10:53
  3. Funk-Wetterstation RW 53
    Von Tim73 im Forum Haustechnik
    Antworten: 2
    Letzter Beitrag: 22.10.12, 12:30
  4. Funk Wetterstation + IPS
    Von quicksim im Forum Haustechnik
    Antworten: 54
    Letzter Beitrag: 01.04.11, 16:03
  5. Was ist per Funk/WLAN möglich?
    Von Macheledt im Forum Alles rund um den PC
    Antworten: 16
    Letzter Beitrag: 27.01.11, 21:37
