+ Antworten
Ergebnis 1 bis 7 von 7
  1. #1
    Registriert seit
    Apr 2007
    Ort
    Lüneburg
    Beiträge
    3,713
    Standard Hilfe bei der Adaption eines Pyhton-Skriptes in PHP
    Hallo Leute,
    für mein PIGPIO-Modul versuche ich einen Code vom PIGPIO-Entwickler selbst für ein modul zu adaptieren.
    Hier fehlt mir aber das Verständnis, wie der Code funktioniert:
    Code:
    #!/usr/bin/env python
    import time
    import pigpio
    def bit_get(word, n):
       Get bit n of word.
       The least significant bit is bit 0.
       return (word>>n)&1
    def bit_set(word, n, value):
       Set bit n of word to value.
       value = (value&1L)<<n
       mask = (1L)<<n
       return (word & ~mask) | value
    def bits_get(word, lsb, msb):
       Get bits lsb to msb of word.
       mask = 2L**(msb + 1 - lsb) - 1
       return (word >> lsb) & mask
    def bits_set(word, lsb, msb, value):
       Set bits lsb to msb of word to value.
       value = (value & mask) << lsb
       mask = mask << lsb
    def bits_reverse(word, lsb, msb):
       Get bits lsb to msb of word and reverse them.
       result = 0
       for i in range(lsb, msb+1):
          if (word >> i) & 1: result |= 1 << (msb - i)
       return result
    def _carrier(gpio, frequency, micros, dutycycle=0.5):
       Generate cycles of carrier on gpio with frequency and dutycycle.
       wf = []
       cycle = 1000000.0 / frequency
       cycles = int(round(micros/cycle))
       on = int(round(cycle * dutycycle))
       sofar = 0
       for c in range(cycles):
          target = int(round((c+1)*cycle))
          sofar += on
          off = target - sofar
          sofar += off
          wf.append(pigpio.pulse(1<<gpio, 0, on))
          wf.append(pigpio.pulse(0, 1<<gpio, off))
       return wf
    class pwc:
       Pulse width coding.
       def __init__(self,
          pi, gpio, freq, mark_0, mark_1, space, duty=0.5):
          self._pi = pi
          self._gpio = gpio
          pi.set_mode(gpio, pigpio.OUTPUT)
          pi.wave_add_new()
          # mark - 0 bit
          pi.wave_add_generic(_carrier(gpio, freq, mark_0, duty))
          self._w_mark_0 = pi.wave_create()
          # mark - 1 bit
          pi.wave_add_generic(_carrier(gpio, freq, mark_1, duty))
          self._w_mark_1 = pi.wave_create()
          # space
          pi.wave_add_generic([pigpio.pulse(0, 0, space)])
          self._w_space = pi.wave_create()
          self._bit = [[self._w_mark_0, self._w_space],
                       [self._w_mark_1, self._w_space]]
       def format(self, data, bits):
          chain = []
          for i in range(bits-1, -1, -1):
             chain += self._bit[(data>>i) & 1]
          return chain
       def w_mark_0(self):
          return self._w_mark_0
       def w_mark_1(self):
          return self._w_mark_1
       def w_space(self):
          return self._w_space
       def cancel(self):
          if self._w_mark_0 is not None:
             self._pi.wave_delete(self._w_mark_0)
             self._w_mark_0 = None
          if self._w_mark_1 is not None:
             self._pi.wave_delete(self._w_mark_1)
             self._w_mark_1 = None
          if self._w_space is not None:
             self._pi.wave_delete(self._w_space)
             self._w_space = None
    class SonySIRC12:
       def __init__(self, pi, gpio, address=0):
          self._pi = pi
          self._gpio = gpio
          self._address = bits_reverse(address&31, 0, 4)
          self._pwc = pwc(pi, gpio, 40000, 600, 1200, 600)
       def set_address(self, address):
       def send_raw(self, data, bits, repeats=1):
          chain = [
             self._pwc.w_mark_1(), self._pwc.w_mark_1(), # 2.4 ms mark
             self._pwc.w_space()]                        # 0.6 ms space
          chain += self._pwc.format(data, bits)
          print(chain)
          for i in range(repeats):
             self._pi.wave_chain(chain)
             time.sleep(0.108)
       def send(self, command, repeats=1):
          command = bits_reverse(command&127, 0, 6)
          data = (command<<5) | self._address
          self.send_raw(data, 12, repeats)
       def cancel(self):
          self._pwc.cancel()
    class pdc:
       Pulse distance coding.
       def __init__(self,
          pi, gpio, freq, mark, bit_0, bit_1, duty=0.5):
          self._pi = pi
          self._gpio = gpio
          pi.wave_add_new()
          # mark
          pi.wave_add_generic(_carrier(gpio, freq, mark, duty))
          self._w_mark = pi.wave_create()
          # space - 0 bit
          pi.wave_add_generic([pigpio.pulse(0, 0, bit_0)])
          self._wid_bit_0 = pi.wave_create()
          # space - 1 bit
          pi.wave_add_generic([pigpio.pulse(0, 0, bit_1)])
          self._wid_bit_1 = pi.wave_create()
          self._bit = [[self._w_mark, self._wid_bit_0],
                       [self._w_mark, self._wid_bit_1]]
          chain = []
          return chain
       def w_mark(self):
          return self._w_mark
       def wid_bit_0(self):
          return self._wid_bit_0
       def wid_bit_1(self):
          return self._wid_bit_1
       def cancel(self):
          if self._w_mark is not None:
             self._pi.wave_delete(self._w_mark)
             self._w_mark = None
          if self._wid_bit_0 is not None:
             self._pi.wave_delete(self._wid_bit_0)
             self._wid_bit_0 = None
          if self._wid_bit_1 is not None:
             self._pi.wave_delete(self._wid_bit_1)
             self._wid_bit_1 = None
    class Sharp:
          self._pi = pi
          self._gpio = gpio
          self._pdc = pdc(pi, gpio, 38000, 320, 680, 1680)
       def send_raw(self, data1, data2, bits, repeats=1):
          chain = (
             self._pdc.format(data1, bits) +
             [255, 2, 0x40, 0x9C] +
             self._pdc.format(data2, bits))
          print(chain)
             time.sleep(0.108)
          command = bits_reverse(command&255, 0, 7)
          cmdexpchk = (command<<2) | 0b10
          inverse = cmdexpchk^0x3FF
          data1 = (self._address<<10) | cmdexpchk
          data2 = (self._address<<10) | inverse
          self.send_raw(data1, data2, 15, repeats)
       def cancel(self):
          self._pdc.cancel()
    class Samsung:
          self._pi = pi
          self._gpio = gpio
          self._address = bits_reverse(address&255, 0, 7)
          self._pdc = pdc(pi, gpio, 38000, 580, 580, 1740)
          chain = [
             255, 0, self._pdc.w_mark(), 255, 1, 8, 0, # 4.5 ms mark
             255, 2, 0x94, 0x11]                       # 4.5 ms space
          chain += self._pdc.format(data, bits)
          print(chain)
             time.sleep(0.108)
          data = (
             (self._address<<25) |
             (self._address<<17) |
             (command<<9) |
             ((command^255)<<1) )
          self.send_raw(data, 33, repeats)
       def cancel(self):
          self._pdc.cancel()
    class NEC:
          self._pi = pi
          self._gpio = gpio
          self._pdc = pdc(pi, gpio, 38000, 553, 572, 1697)
          chain = [
             255, 0, self._pdc.w_mark(), 255, 1, 16, 0, # 9 ms mark
          print(chain)
             time.sleep(0.1)
          data = (
             ((self._address^255)<<17) |
             (command<<9) |
       def cancel(self):
          self._pdc.cancel()
    class SANYO:
          self._pi = pi
          self._gpio = gpio
          self._address = bits_reverse(address&0x1FFF, 0, 12)
          self._pdc = pdc(pi, gpio, 38000, 553, 553, 1659)
          chain = [
          print(chain)
             time.sleep(0.1)
          data = (
             (self._address<<29) |
             ((self._address^0x1FFF)<<16) |
             (command<<8) |
             (command^255) )
          self.send_raw(data, 42, repeats)
       def cancel(self):
          self._pdc.cancel()
    class JVC:
          self._pi = pi
          self._gpio = gpio
          self._pdc = pdc(pi, gpio, 38000, 526, 524, 1574)
          chain = [
             255, 0, self._pdc.w_mark(), 255, 1, 16, 0, # 8.4 ms mark
             255, 2, 0x68, 0x10]                        # 4.2 ms space
          print(chain)
          time.sleep(0.055)
          chain = self._pdc.format(data, bits)
          for i in range(repeats-1):
             time.sleep(0.055)
          data = (self._address<<8) | command
          self.send_raw(data, 16, repeats)
       def cancel(self):
          self._pdc.cancel()
    class bip:
       Bi-phase (Manchester) coding.
       def __init__(self,
          pi, gpio, freq, mark, space, rising_1, duty=0.5):
          self._pi = pi
          self._gpio = gpio
          self._rising_1 = rising_1
          pi.wave_add_new()
          # mark
          # space
          if rising_1:
             self._bit = [[self._w_mark, self._w_space],
                          [self._w_space, self._w_mark]]
          else:
             self._bit = [[self._w_space, self._w_mark],
                          [self._w_mark, self._w_space]]
          chain = []
          return chain
       def w_space(self):
       def w_mark(self):
          return self._w_mark
       def cancel(self):
             self._w_mark = None
    class NRC17:
       Nokia.
       def __init__(self, pi, gpio, address=0, subcode=0):
          self._pi = pi
          self._gpio = gpio
          self._address = bits_reverse(address&15, 0, 3)
          self._subcode = bits_reverse(subcode&15, 0, 3)
          self._bip = bip(pi, gpio, 38000, 500, 500, False)
       def set_subcode(self, subcode):
          start_stop = [
             self._bip.w_mark(), # 0.5 ms mark
             255, 2, 0xC4, 0x09]     # 2.5 ms space
          ss = 1<<16 | 0x7F<<8 | 0xFF
          start_stop += self._bip.format(ss, 17)
          chain = [
          chain += self._bip.format(data, bits)
          print(chain)
          self._pi.wave_chain(start_stop)
          time.sleep(0.04)
             time.sleep(0.1)
          time.sleep(0.04)
          data = (
             (1<<16) |
             (command<<8) |
             (self._address<<4) |
             self._subcode )
          self.send_raw(data, 17, repeats)
       def cancel(self):
          self._bip.cancel()
    class RC5:
          self._pi = pi
          self._gpio = gpio
          self._address = address&31
          self._toggle = 0
          self._bip = bip(pi, gpio, 36000, 889, 889, True)
          print(bin(data), bits, repeats)
          chain = self._bip.format(data, bits)
          #print(chain)
             time.sleep(0.1)
          command &= 63
          if self._toggle:
             self._toggle = 0
          else:
             self._toggle = 1
          data = (3<<12) | (self._toggle<<11) | (self._address<<6) | command
          self.send_raw(data, 14, repeats)
       def cancel(self):
          self._bip.cancel()
    class RC5X:
          self._pi = pi
          self._gpio = gpio
          self._toggle = 0
          print(chain)
             time.sleep(0.1)
          if self._toggle:
             self._toggle = 0
          else:
             self._toggle = 1
          command &= 127
          if command & 64:
             field = 0
             command &= 63
          else:
             field = 1
          data = (
             (1<<13) |
             (field<<12) |
             command )
       def cancel(self):
          self._bip.cancel()
    class RC6_0:
          self._pi = pi
          self._gpio = gpio
          self._address = address&255
          self._toggle = 0
          self._bip = bip(pi, gpio, 36000, 889, 889, False)
          mark = self._bip.w_mark()
          space = self._bip.w_space()
          if self._toggle:
             trailer = [mark, mark, space, space]
          else:
             trailer = [space, space, mark, mark]
          chain = [mark, mark, mark, space]
          chain += self._bip.format(0b1000, 4)
          chain += trailer
          print(chain)
             time.sleep(0.1)
          if self._toggle:
             self._toggle = 0
          else:
             self._toggle = 1
          command &= 255
       def cancel(self):
          self._bip.cancel()
    class RC6_6A_SCC:
          self._pi = pi
          self._gpio = gpio
          self._address = address&127
          chain += self._bip.format(0b1110, 4)
          chain += [space, space, mark, mark] # Trailer (6A=0, 6B=1).
          print(chain)
             time.sleep(0.1)
       def send(self, command, bits, repeats=1):
          command &= ((1<<bits)-1)
          data = (self._address<<bits) | command
          self.send_raw(data, bits+8, repeats)
       def cancel(self):
          self._bip.cancel()
    class RC6_6A_LCC:
          self._pi = pi
          self._gpio = gpio
          self._address = address&0x7FFF
          print(chain)
             time.sleep(0.1)
          self.send_raw(data, bits+16, repeats)
       def cancel(self):
          self._bip.cancel()
    class SamsungRead:
       Decodes a Samsung remote control (32 bits, 16 address, 16 command).
       def __init__(self, pi, gpio):
          self._pi = pi
          self._gpio = gpio
          self._lt = None
          self._code = 0
          self._bits = 0
          pi.set_mode(gpio, pigpio.INPUT)
          self._cb = pi.callback(gpio, pigpio.EITHER_EDGE, self._cbf)
       def _cbf(self, g, l, t):
          if self._lt is not None:
             td = pigpio.tickDiff(self._lt, t)
             if l == 0:
                self._code = self._code << 1
                self._bits += 1
                if td > 3000:
                   self._code = 0
                   self._bits = 0
                elif td > 1000:
                   self._code = self._code | 1
                if self._bits == 32:
                   print(hex(self._code))
          self._lt = t
    class ITT:
          self._pi = pi
          self._gpio = gpio
          wf = [pigpio.pulse(1<<self._gpio, 0, 10),
                pigpio.pulse(0, 1<<self._gpio, 300),
                pigpio.pulse(0, 1<<self._gpio, 100)]
          data = (self._address<<6) | command
          for i in range(9, -1, -1):
             wf.append(pigpio.pulse(1<<self._gpio, 0, 10))
             if data & (1<<i):
                wf.append(pigpio.pulse(0, 1<<self._gpio, 200))
             else:
                wf.append(pigpio.pulse(0, 1<<self._gpio, 100))
          wf.append(pigpio.pulse(0, 1<<self._gpio, 300))
          wf.append(pigpio.pulse(0, 1<<self._gpio, 0))
          self._pi.wave_add_generic(wf)
          wid1 = self._pi.wave_create()
          data = ((self._address^15)<<6) | command
             if data & (1<<i):
             else:
          wid2 = self._pi.wave_create()
          self._pi.wave_send_once(wid1)
          time.sleep(0.13)
             self._pi.wave_send_once(wid2)
             time.sleep(0.13)
          self._pi.wave_delete(wid1)
          self._pi.wave_delete(wid2)
       def cancel(self):
          pass
    if __name__ == "__main__":
       import ir_protocol
       GPIO=23
       GPIO_RX=8
       pi = pigpio.pi()
       #r = SamsungRead(pi, GPIO_RX)
       #time.sleep(60)
       GPIO_mode = pi.get_mode(GPIO)
       s1 = ir_protocol.RC6_0(pi, GPIO)
       s2 = ir_protocol.RC5(pi, GPIO)
       for a in range(256):
          s1.set_address(a)
          s2.set_address(a)
          for c in range(256):
             s1.send(c, 2)
             s2.send(c, 2)
             time.sleep(0.2)
             print(a, c)
       s.cancel()
       pi.set_mode(GPIO, GPIO_mode)
       pi.stop()
    Wie würde ich hier vorgehen, wenn ich z.B. mit der class RC5: einen Befehl absetzen wollen würde?
    Joachim
    IP-Symcon seit 12/2009, iPhoneApp seit 01/2011, IPSView seit 12/2014!
    3xSiemensLOGO0BA7+DM16, 1xInstar 3010PoE, 1xInstar 2905PoE, 1x1-WireHub mit DS2450 von Eservice-online, 15xDS1820, 1xDS2423, 1xDS2408
  2. #2
    Registriert seit
    Jun 2012
    Ort
    House of Dragons @ Lübeck
    Beiträge
    10,289
    Dürfte schon am import pigpio scheitern.
    Das ist eine Erweiterung von Entwickler für pyhton.
    Die bekommst du nicht in PHP geladen.
    on Win10VM (ESXi): I7, 32GB RAM, HW-RAID5, 2xSat | HW: pivccu + ca.130 Geräte (ca.550ch), EM1000, CUL, 1Wire, FritzBox Cable, Android Phone + Tablet, Onkyo NR| SW: IPS, Apache2(mod_ssl/PHP), MySQL, hMailServer, PRTG, RoundCube, Win2016 Ess., MediaPortal, Kodi
  3. #3
    Registriert seit
    Apr 2007
    Ort
    Lüneburg
    Beiträge
    3,713
    Hallo Michael,
    das sollte kein Problem darstellen, benutze duzende PIGPIO-Funktionen in meinem Modulen...
    Geht darum, wo der "Einsprung" wäre...
    Joachim
  4. #4
    Registriert seit
    Jun 2012
    Ort
    Beiträge
    10,289
    Script.. fängt oben an.
    Der Konstruktor für die Klassen ist das folgenden def __init__.
    Bin aber aber auch nicht fit, habe lediglich 2-3 Scripte für meinen Pi angepasst.
  5. #5
    Registriert seit
    Apr 2007
    Ort
    Lüneburg
    Beiträge
    3,713
    ...versuche mich immer noch in der Anpassung...mühsam ernährt sich das Eichhörnchen...
    Immer wieder kommt etwas im Skript vor wie:
    Self bedeutet wohl: Bezieht sich auf eine Funktion in der eigenen Klasse (?)
    Aber dieses "_bit"?
    Eine Funktion? Finde aber keine die so definiert ist...
    Joachim
  6. #6
    Registriert seit
    May 2005
    Beiträge
    2,325
    self._bit ist eine Klassenvariable, hier als Array. Mit dem Befehl in Deinem Beispiel wird das _bit Array an Bitpostition i von Data als 0 oder 1 gelesen. Der Inhalt von _bit ist ein paar Zeilen höher definiert worden..
    Code:
    Tommi
  7. #7
    Registriert seit
    Apr 2007
    Ort
    Lüneburg
    Beiträge
    3,713
    Hallo Tommi,
    vielen Dank erst einmal - werde mich weiter versuchen an der Adaption...
    Joachim
Ähnliche Themen
  1. Pyhton Script in PHP portieren
    Von KaiS im Forum Skripte, PHP, SQL
    Antworten: 29
    Letzter Beitrag: 09.02.18, 17:22
  2. Fehler bei Anzeige eines Skriptes in IPS Studio
    Von geolin im Forum IPSStudio & IPSView
    Antworten: 5
    Letzter Beitrag: 07.10.17, 21:44
  3. Fehler beim Ausführen eines Aktion-Skriptes
    Von Schneider im Forum IPSStudio & IPSView
    Antworten: 3
    Letzter Beitrag: 07.05.16, 08:51
  4. Durchlauf eines Skriptes nach Änderung der Variable
    Von JPaeper im Forum Allgemeine Diskussion
    Antworten: 18
    Letzter Beitrag: 26.12.15, 10:26
  5. Ereignis auf Link eines Skriptes
    Von Smokey im Forum Skripte, PHP, SQL
    Antworten: 1
    Letzter Beitrag: 06.11.11, 21:04
