+ Antworten
Ergebnis 1 bis 4 von 4
  1. #1
    Registriert seit
    Dec 2009
    Beiträge
    38
    Standard Temperature sensor for higher temperatures
    my temperature threshold sensor (FS20) just died. I used it to detect that fireplace is in use.
    Is there any temperature sensor which can measure higher temperatures (at least 80 degrees) which will work with IP Symcon without having to buy some expensive central unit?
    I run IP Symcon in Linux container on Proxmox server so WLAN device would probably be easiest.
    I currently run a mix of old FS20 components which I want to replace as they die (which they started do one after another) with something new, so a lot of research in front of me as my knowledge is FS20-old.
    Thanks
  2. #2
    Registriert seit
    Sep 2008
    Ort
    Staufenberg nr KS
    Beiträge
    2,038
    i´m using the TermoJet with 6xinput 55~125°C an 2xinput up to 1000°C
    Using the JKM868, you can use it directly to IPS. but I didn`t find jkm in any shop.
    IP-Symcon Version: 5.4 ninja - unlim auf WIN7pro
    Shuttle XS35V4,HPSlate21,IPS-868,HM,HMip,FS20,piVCCU3,Silex4000,IPcams, FB 7850, TM-D710GE(GPS), Raspi3, Pioneer VSX, Libratone, MieleWCR870WPS, SamsungNZ64N7777
  3. #3
    Registriert seit
    Dec 2009
    Beiträge
    38
    thnks, I'll have a look
  4. #4
    Registriert seit
    Jan 2010
    Ort
    Utrecht, Netherlands
    Beiträge
    92
    Standard I use 1-wire for this
    Hi Marian,
    I use 1-wire just for the temperature measurements (about 12 of them). The DS18B20 will go until 125 degrees. You can find them for € 4- € 5 in the shops. With a lan to 1-wire adapter its easy to connect it to IPS. Very stable solution...
    Take care,
    Robert
Ähnliche Themen
  1. Antworten: 3
    Letzter Beitrag: 29.11.18, 07:30
  2. Strange temperature measurement CSEZ-01/17.
    Von albertoosten im Forum General Discussion
    Antworten: 3
    Letzter Beitrag: 25.11.15, 20:04
  3. xComfort: Temperature setting on CHVZ-01/03.
    Antworten: 2
    Letzter Beitrag: 27.03.12, 17:26
  4. Profil ~Temperature.FHT in der Konsole
    Von hightower im Forum Allgemeine Diskussion (2.x/3.x)
    Antworten: 3
    Letzter Beitrag: 22.06.11, 06:56
  5. Profil ~Temperature.FHT
    Von RWN im Forum Allgemeine Diskussion (2.x/3.x)
    Antworten: 2
    Letzter Beitrag: 06.09.09, 20:53
