Hello,
First of all I want to complement you with the program. As you can see I am a newbe … and have some questions.
For now your manual is talking about connecting to HomeMatic trough the Central CCU1. But there are also a HomeMatic LAN and a USB connector. Does IP Symcon support these already? Which one do you advice, LAN or USB?
[url = http://www.elv.de/HomeMatic-LAN-Konfigurations-Adapter/x.aspx/cid_74/detail_10/detail2_26240/flv_/bereich_/marke_] HomeMatic LAN Adapter Configuration | ELV Elektronik [/ url]
Thanks to Google a lot can be translated into English (manuals, forum, etc). I know there has been two post about a English version but … no clear answer yet. So, are there plans to make a English and Dutch: D version? I think that other countries will enjoy your work!
I have a 1wire network at home with more parts than you support now. I also have a hub, barometer, temperture / humidity meters, uv-meters, solar-meter. Are there plans to support these as well? If not will I be able to build my own connector?
Regards,
Robert
