Computation Module
Require: IP-Symcon >= 4.3
This module can perform various auxiliary calculations on a set of variables, for example, the sum or the average.
function scope
  • Calculations of various values based on a set of variables:
    • Sum
    • Minimum
    • Maximum
    • Average
    • Number of variables
  • Output of the calculated values in variables
  • Updating of the values as soon as one of the variables changes
software installation
  • Under "Add Instance", the 'Computation Modulel' can be found using the quick filter.
configuration page:
name description
Calculation Selection of the performed calculation(s)
Variables VariableIDs of the variables on which the calculation(s) will be performed; for all calculations except Number, all variables must be of type Float or Integer
_possiblecalculations:
Name Description
All All calculations presented in this table are performed
Sum The sum of all selected variables is stored in the status variable Sum
Minimum The minimum value of the selected variables is stored in the Minimum status variable
Maximum The maximum value of the selected variables is stored in the status variable Maximum
Average The average of the selected variables is stored in the status variable Average
Number The number of selected variables is stored in the status variable Number
status variables
Status variables
A corresponding status variable is created for each calculation.
Name Type Description
Sum Float The sum of all selected variables
Minimum Float The minimum value of the selected variables
Maximum Float The maximum value of the selected variables
Average Float The average of the selected variables
Number Float The number of selected variables
