boolean ModBus_WriteRegisterInteger (integer $InstanceID, integer $Value)
Value | -2147483648 bis 2147483647 |
If the command succeeds, it returns TRUE, otherwise FALSE. |
Sets address with ID InstanceID to Value
//Writes -123 into the register of the instance with the ID 12345 ModBus_WriteRegisterInteger(12345, -123);
