Heute hab ich endlich geschafft mit IPS meine Haustür zu Öffnen.
Ausgangssituation:
TürAktor an Euracom per Telefon Code #071 zu Öffnen
Fritzbox 7390 an Euracom per Analog Anschluss an der Fritzbox
Über ISDN_Connect hab ich alles Möglich versucht die #071 über die Fritzbox an die Euracom zu bekommen, aber keine Chance.
Da blieb also nur die Wahlhilfe.
Ich habe mir aus den fritzbox-7270-wlan-repeater-scripts folgendes zusammenkopiert:
fritzbox.conf.php
#################### the config #####################
# set to your Fritz!Box IP address or DNS name (defaults to fritz.box), for remote config mode, use the dyndns-name like example.dyndns.org
$fritzbox_ip = 'fritz.box';
# if needed, enable remote config here
#$enable_remote_config = true;
#$remote_config_user = 'test';
#$remote_config_password = 'test123';
# set to your Fritz!Box password (defaults to no password)
$password = "password";
# set the logging mechanism (defaults to console logging)
$logging = 'console'; // output to the console
#$logging = 'silent'; // do not output anything, be careful with this logging mode
#$logging = 'tam.log'; // the path to a writeable logfile
# the newline character for the logfile (does not need to be changed in most cases)
$newline = (PHP_OS == 'WINNT') ? "
############## module specific config ###############
# set the path for the call list for the foncalls module
$foncallslist_path = dirname(__FILE__) . '/foncallsdaten.xml';
fritzbox_api.class.php
* Fritz!Box API - A simple wrapper for automatted changes in the Fritz!Box Web-UI
* handles the new secured login/session system and implements a cURL wrapper
* new in v0.2: Can handle remote config mode via https://example.dyndns.org
* new in v0.3: New method doGetRequest handles GET-requests
* @author Gregor Nathanael Meyer <Gregor [at] der-meyer.de>
* @license http://creativecommons.org/licenses/by-sa/3.0/de/ Creative Commons cc-by-sa
* @version 0.3 2010-05-19
* @package Fritz!Box PHP tools
/* A simple usage example
* require_once('fritzbox_api.class.php');
* try
* $fritz = new fritzbox_api('password', 'fritz-box');
* $formfields = array(
* 'getpage' => '../html/de/menus/menu2.html', // the getpage parameter is mandatory
* 'tam:settings/TAM0/Active' => 1, // enables the first answering machine, any POST-field from the Web-UI can be used
* $fritz->doPostForm($formfields); // send the command
* $fritz = null; // destroy the object to log out
* catch (Exception $e)
* echo $e->getMessage(); // schow the error message in anything failed
* the main Fritz!Box API class
class fritzbox_api {
* @var string the Fritz!Box password, set by the constructor
protected $password;
* @var bool enable remote config mode, set by the constructor
protected $enable_remote_config;
* @var string username for remote config mode, set by the constructor
protected $remote_config_user;
* @var string password for remote config mode, set by the constructor
protected $remote_config_password;
* @var string the Fritz!Box base URL, set by the constructor
protected $fritzbox_url;
* @var string the session ID, set by method initSID() after login
protected $sid = '0000000000000000';
* the constructor, initializes the object and calls the login method
* @access public
* @param string $password the Fritz!Box password, optional, defaults to null
* @param string $fritzbox_ip the Fritz!Box IP address or DNS name, optional, defaults to fritz.box
* @param bool $enable_remote_config set true to enable remote config, optional, defaults to false
* @param string $remote_config_user the remote config username, mandatory, if remote config is used
* @param string $remote_config_password the remote config password, mandatory, if remote config is used
public function __construct($password = null, $fritzbox_ip = 'fritz.box', $enable_remote_config = false, $remote_config_user = null, $remote_config_password = null)
$this->password = $password;
if ( $enable_remote_config === true )
if ( !isset($remote_config_user) || !isset($remote_config_password) )
$this->error('ERROR: Remote config mode enabled, but no username or no password provided');
$this->fritzbox_url = 'https://' . $fritzbox_ip;
$this->enable_remote_config = true;
$this->remote_config_user = $remote_config_user;
$this->remote_config_password = $remote_config_password;
else
$this->fritzbox_url = 'http://' . $fritzbox_ip;
$this->enable_remote_config = false;
$this->remote_config_user = null;
$this->remote_config_password = null;
$this->sid = $this->initSID();
* the destructor just calls the logout method
* @access public
public function __destruct()
$this->logout();
* do a POST request on the box
* the main cURL wrapper handles the command
* @access public
* @param array $formfields an associative array with the POST fields to pass
* @return string the raw HTML code returned by the Fritz!Box
public function doPostForm($formfields = array())
// add the sid, if it is already set
if ($this->sid != '0000000000000000')
$formfields['sid'] = $this->sid;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $this->fritzbox_url . '/cgi-bin/webcm');
curl_setopt($ch, CURLOPT_POST, 1);
if ( $this->enable_remote_config )
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($ch, CURLOPT_USERPWD, $this->remote_config_user . ':' . $this->remote_config_password);
curl_setopt($ch, CURLOPT_POSTFIELDS, http_build_query($formfields));
$output = curl_exec($ch);
curl_close($ch);
return $output;
* do a GET request on the box
* @access public
* @param array $params an associative array with the GET params to pass
public function doGetRequest($params = array())
$params['sid'] = $this->sid;
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, $this->fritzbox_url . '/cgi-bin/webcm?' . http_build_query($params));
curl_setopt($ch, CURLOPT_HTTPGET, 1);
curl_close($ch);
return $output;
* the login method, handles the secured login-process
* newer firmwares (xx.04.74 and newer) need a challenge-response mechanism to prevent Cross-Site Request Forgery attacks
* see http://www.avm.de/de/Extern/Technical_Note_Session_ID.pdf for details
* @access protected
* @return string a valid SID, if the login was successful, otherwise throws an Exception with an error message
protected function initSID()
// read the current status
$ch = curl_init($this->fritzbox_url . '/cgi-bin/webcm?getpage=../html/login_sid.xml');
curl_close($ch);
$session_status_simplexml = simplexml_load_string($output);
// perhaps we already have a SID (i.e. when no password is set)
if ($session_status_simplexml->iswriteaccess == 1)
return $session_status_simplexml->SID;
// we have to login and get a new SID
else
// the challenge-response magic, pay attention to the mb_convert_encoding()
$challenge = $session_status_simplexml->Challenge;
$response = $challenge . '-' . md5(mb_convert_encoding($challenge . '-' . $this->password, "UCS-2LE", "UTF-8"));
// do the login
'login:command/response' => $response,
$output = $this->doPostForm($formfields);
// finger out an error message, if given
preg_match('@<p class="errorMessage">(.*?)</p>@is', $output, $matches);
if (isset($matches[1]))
$this->error(str_replace(' ', ' ', $matches[1]));
// finger out the SID from the response
preg_match('@<input type="hidden" name="sid" value="([A-Fa-f0-9]{16})" id="uiPostSid">@i', $output, $matches);
if (isset($matches[1]) && $matches[1] != '0000000000000000')
return $matches[1];
else
$this->error('ERROR: Login failed with an unknown response');
* the logout method just sends a logout command to the Fritz!Box
* @access protected
protected function logout()
'security:command/logout' => 'logout',
* the error method just throws an Exception
* @access protected
* @param string $message an error message for the Exception
protected function error($message = null)
throw new Exception($message);
* a getter for the session ID
* @access public
* @return string $this->sid
public function getSID()
return $this->sid;
und dann ein Script in IPS angelegt
try
$fritz = new fritzbox_api('password', 'fritz.box');
'telcfg:settings/UseClickToDial' => 1, // enables the first answering machine, any POST-field from the Web-UI can be used
"telcfg:command/Dial"=>"*10#*##071",
"telcfg:settings/DialPort"=>"50"
und siehe da. Der Türsummer summt.
