I have a problem showing objects inside a Dummy Module and other items under a category since the upgrade to IPS 3.0. This is only in the WebFront, in the iFront on my mobile all is working fine.
I added some images:
[ul]
[li]When an object is placed directly under the shown category, like the color in this case, it’s showing in the Webfront.
[/li][li]When an object like a Dummy Module or other category is places under the shown category, only the Strings are shown and not the other object inside the Strings?
[/li][li]The third image is form IPS, to show how I made it.
[/li][li]
[/li][/ul]
It looks like the objects in a string are not shown. Normally this is done with Dummy Modules, but I discovered that later and a lot of items are made this way. And it worked fine till IPS 3.0.
I hope someone can help me with this problem.
Thanks ……….
Albert
