I have IP-Symcon installed on an Odroid C2 running Ubuntu 16.04. Everything has been working fine for the past month with some 1-Wire sensors attached to a Symcon 1-Wire LAN Gateway. Today I was planning work on a PHP-Module. Unfortunately I am unable to add PHP modules.
When I try to add a module from a GitHub repository I get the following error:
"Error: Failed to resolve address for github.com: Temporary failure in name resolution".
When I try a https URL instead I get the error:
"Error: SSL error: error:140E0114LSSL routines:SSL_shutdown:uninitialized."
The IP-Symcon Connect connection is also in error state. Message from the message log:
"Cannot contact IP-Symcon Live srver. Message: try again later"
On the command line the system has no issues resolving domain names.
Any idea how I can fix this issue?
Can you check your resolv.conf if you have a valid IPv4 DNS Server?
There are valid IPv4 DNS servers configured in /etc/resolv.conf.
I am not able to resolve any addresses in PHP scripts in the Symcon environment:
Warning: dns_get_record(): A temporary server error occurred. in /var/lib/symcon/scripts/53031.ips.php on line 11
Warning: file_get_contents(): php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution in /var/lib/symcon/scripts/53031.ips.php on line 15
Warning: file_get_contents(http://www.example.com/): failed to open stream: php_network_getaddresses: getaddrinfo failed: Temporary failure in name resolution in /var/lib/symcon/scripts/53031.ips.php on line 15
For now, adding the address to /etc/hosts or using Github’s IP in the URL of a repository is a workaround.
I am using Symcon on Ubuntu arm64 with armhf as a foreign architecture, maybe that’s causing some issues.
