PHP-Code:
// Klassendefinition
class YeelightColorBulb extends IPSModule {
// Der Konstruktor des Moduls
public function __construct($InstanceID) {
// Diese Zeile nicht löschen
parent::__construct($InstanceID);
// Selbsterstellter Code
public function Create() {
parent::Create();
$this->RegisterPropertyString("ipadress", "");
$this->RequireParent("{3CFF0FD9-E306-41DB-9B5A-9D06D38576C3}"); // CLIENT SOCKET
public function ApplyChanges() {
parent::ApplyChanges();
$this->RegisterVariableBoolean("power", "Power", "~Switch", 0);
$this->RegisterVariableInteger("bright", "Brightness", "~Intensity.100", 1);
$this->RegisterVariableInteger("ct", "Color Temperature", "~Intensity.65535", 2);
$this->RegisterVariableInteger("rgb", "Color", "~HexColor", 3);
$this->RegisterVariableString("hue", "Hue", "~String", 4);
$this->RegisterVariableInteger("sat", "Saturation", "~Intensity.100", 5);
$this->RegisterVariableInteger("color_mode", "Color Mode", "", 6);
$this->GetConfigurationForParent();
$this->EnableAction("power");
$this->EnableAction("bright");
$this->EnableAction("rgb");
$this->EnableAction("sat");
public function GetConfigurationForParent()
$host = $this->ReadPropertyString("ipadress");
$port = 55443;
return "{\"Host\": \"$host\", \"Port\": \"$port\"}";
// Lese alle Konfigurationsdaten aus
public function readStatesFromDevice() {
$this->buildAndSendCommand('444', 'get_prop', array('power', 'bright', 'ct', 'rgb', 'hue', 'sat', 'color_mode'));
public function ReceiveData($JSONString)
$data = json_decode($JSONString);
$payload = json_decode($data->Buffer);
//27/12/2017 16:06:33 | Receive | {"id":1, "result":["off","27","2945","255","359","100","2"]}
// this is our Datafetch from Configuration GUI, which has a fixed sorting of values
if (isset($payload->id) && '444' == $payload->id) {
SetValueBoolean(IPS_GetObjectIDByIdent("power", $this->InstanceID), 'on' == $payload->result[0] ? TRUE : FALSE);
SetValueInteger(IPS_GetObjectIDByIdent("bright", $this->InstanceID), $payload->result[1]);
SetValueInteger(IPS_GetObjectIDByIdent("ct", $this->InstanceID), $payload->result[2]);
SetValueInteger(IPS_GetObjectIDByIdent("rgb", $this->InstanceID), $payload->result[3]);
SetValueString(IPS_GetObjectIDByIdent("hue", $this->InstanceID), $payload->result[4]);
SetValueInteger(IPS_GetObjectIDByIdent("sat", $this->InstanceID), $payload->result[5]);
SetValueInteger(IPS_GetObjectIDByIdent("color_mode", $this->InstanceID), $payload->result[6]);
IPS_LogMessage("Reciever", "done");
return;
//IPS_LogMessage("Receiver", utf8_decode($data->Buffer));
//27/12/2017 17:40:01 | Receiver | {"method":"props","params":{"power":"off"}}
if (isset($payload->method) && 'props' == $payload->method) {
foreach ($payload->params as $key => $val) {
if ('power' == $key) {
SetValueBoolean(IPS_GetObjectIDByIdent("power", $this->InstanceID), 'on' == $val ? TRUE : FALSE);
} else if ('bright' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("bright", $this->InstanceID), $val);
} else if ('ct' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("ct", $this->InstanceID), $val);
} else if ('rgb' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("rgb", $this->InstanceID), $val);
} else if ('hue' == $key) {
SetValueString(IPS_GetObjectIDByIdent("hue", $this->InstanceID), $val);
} else if ('sat' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("sat", $this->InstanceID), $val);
} else if ('color_mode' == $key) {
SetValueInteger(IPS_GetObjectIDByIdent("color_mode", $this->InstanceID), $val);
} else {
IPS_LogMessage("YeelightColorBulb", "Unknown Notification received " . utf8_decode($data->Buffer));
public function RequestAction($Ident, $Value)
IPS_LogMessage("RequestAction ", utf8_decode($Ident) . " value: " . $Value);
switch ($Ident) {
case "power":
$this->Power($Value);
break;
case "bright":
$this->Brightness($Value);
break;
case "rgb":
$this->RGB($Value);
break;
case "sat":
$this->Saturation($Value);
break;
default:
throw new Exception("Invalid Ident: " . $Ident);
public function Power($Value)
$this->buildAndSendCommand(10, "set_power", array($Value ? 'on' : 'off', 'smooth', 500));
public function Brightness($Value)
$this->buildAndSendCommand('20', "set_bright", array($Value));
public function RGB($Value)
$this->buildAndSendCommand(10, "set_rgb", array($Value, 'smooth', 500));
public function Saturation($Value)
$this->buildAndSendCommand(10, "set_hsv", array(0, $Value, 'smooth', 500));
private function buildAndSendCommand($id, $method, $params)
$Data = Array(
'id' => $id,
'method' => $method,
'params' => $params
$payload = json_encode($Data);
$this->SendDataToParent(json_encode(Array(
"DataID" => "{79827379-F36E-4ADA-8A95-5F8D1DC92FA9}",
"Buffer" => $payload . "\r\n"
