well i am trying to send email from PHP Code integrtae with HTML. SMTP_SendMail is also funtionin right with no Problems. Problem is when i wan to send emsail in Outlook i am not getting the right Format of Output of my email in Outlook. it Shows HTML Code with HTML Tags. I want to know can we use headers in IP_symcon PP Code here OR is there any possibilty that i can get right HTML Output Format in MS Outlook. When i run my Code it Shows right out in IP_Symcon Sktripausgabe
but not in MSOUtLook.
Any Help will be apprecitable.
my test Code from PHP IP-Symcon ias follows:-
$message = '<html>'."
$message .= '<head></head>'."
$message .= '<body>'."
$message .= '<h1 style="color:#f40;">PHP</h1>'."
$message .= '<p style="color:#080;font-size:18px;">IP_Symcon Management Console[IP_Symcon]</p>'."
$message .= '</body>'."
$message .= '</html>'."
SMTP_SendMail( /*[E-Mail, Send (SMTP)]*/,"", $message);
This way you are sending Plain-Text Emails, for HTML you can use for example PHPMailer or any description found by google for PHP for example here. Another way would be to add a feature request to IP-Symcon for HTML E-mail support by IP-Symcon methods.
I think the method SMTP_SendMail supports only plain text at the moment. So you could write in Funktionswünsche to add a special method for HTML email, so that you don’t have to use another class or script code to send html email by PHP.
You can try also
mail($to, $subject, $message, $headers);
instead of using
SMTP_SendMail(12345, "Alarm!", "Die Heizung ist ausgefallen!");
yes. i have also treid this but in Outlook i am gettinng Email with Text False. One Thing which quite sure that we cannot use headers here in this Format. How can i use PHPMailer() class here IP-Symcon?
