Ergebnis 1 bis 3 von 3
    Aug 2016
    11
    Standard Cannot delete instance
    During testing of a home-build module I created a I/O instance (serial port) but I failed to construct the child instance due to some errors. No big deal you'd say, but I cannot delete the created I/O instances as my attempt to delete these gives the following error:
    Could not delete object
    Flow for Instance #17837 does not exist (Code: -32603)
    The instance ID it refers to seems to be the reserved ID for the child that was never/partially created. I cannot delete these, also IPS_DeleteInstance gives a similar result. The Instance ID it refers to is also non-existent.
    Sep 2014
    Limeshain (Hessen)
    5,327
    Hi!
    Have you restarted your IP-Symcon service? This always helps me if the IPS behaves as described by you.
    Either the object is deleted after the IPS restart, or then i can delete it without problems.
    Kind regards,
    Chris
    Aug 2016
    11
    I tried to restart the Symcon service but it did not have any effect.
    This morning, after a full reboot of the raspberry Pi I could delete these instances. Finally
  1. Delete invalid values in archive dataset
    Von HerwinJan im Forum Allgemeine Diskussion
    Letzter Beitrag: 20.11.18, 21:41
  2. Cannot delete association for boolean types
    Von Fonzo im Forum Entwicklung mit PHP-SDK/Delphi-SDK
    Letzter Beitrag: 12.11.18, 19:34
  3. Eigenen Listner auf die Delete funktion?
    Von n00d13 im Forum Entwicklung mit PHP-SDK/Delphi-SDK
    Letzter Beitrag: 23.05.17, 16:25
  4. Eigenen Listner auf die Delete funktion?
    Von n00d13 im Forum Skripte, PHP, SQL
  5. FTDI I/O instance
    Von mraza im Forum General Discussion
    Letzter Beitrag: 12.08.13, 11:49
