I am trying to develop an arbitrary module that, among others, creates various variables during creation. Ideally, these variables should be logged as well.
This can be set using the AC_SetLoggingStatus, but this function returns an error in the example below. The $this->GetIDForIdent(‚consumptionT1‘) returns an object ID, which indicates it exists, but AC_SetLoggingStatus returns an error stating that the object does not exist. I can imagine that this happens when this function is called in the Create() part of the module, but I do not expect this to happen in the ApplyChanges() part.
What would be the proper way of creating a variable and setting variable properties such as logging?
class P1SmartMeter extends IPSModule
public function Create()
//Never delete this line!
parent::Create();
// Requires a Serialport I/O as parent.
$this->RequireParent("{6DC3D946-0D31-450F-A8C6-C42DB8D7D4F1}");
// Set variables used for settings.
$this->RegisterPropertyInteger("DaysToKeep", "10");
$this->RegisterVariableFloat("consumptionT1", "Electricity consumption low", "Electricity", 10);
// Set timer for automatic data removal for historic data
$this->RegisterTimer("DataRemoval", 0, 'P1_PurgeOldData');
public function ApplyChanges()
parent::ApplyChanges();
$this->SetTimerInterval("DataRemoval", $this->ReadPropertyInteger("DaysToKeep")*24*60*60*1000);
// Set variables for smart meter data
// Get ObjectID for first archive
$archives = IPS_GetInstanceListByModuleID("{43192F0B-135B-4CE7-A0A7-1475603F3060}");
AC_SetLoggingStatus($this->GetIDForIdent('consumptionT1'), $archives[0], true);
