Work Efficiency
Require: Symcon >= 6.3
The efficiency is calculated.
function scope
  • The efficiency for the past 365 days
  • The efficiency for the past 30 days
software-installation
Using the Module Store, install the 'work efficiency' module.
Under 'Add Instance' the 'Work efficiency' module can be found using the quick filter.
configuration page
name description
Thermal energy (kWh) Variable logged as counter
Electrical Energy (kWh) Variable which is logged as counter
status variables
Name Type Description
SPF Month Float Stands for the sessional performance facto on month
SPF Year Float Stands for the sessional performance factor on year
