Expert Options
Require: Symcon >= 5.0
The Expert Options usually do not need to be adjusted. Handle these options carefully to ensure that the Amazon Alexa module works as intended.
Options
Name Description
Emulate Status If Emulate Status is active, the module does not wait for the update of switched variables. Instead, it returns the new state based on the triggered value.
Show Expert Devices If Show Expert Devices is active, expert devices are displayed. Expert devices are devices that are more complex in the configuration and require a deeper understanding of IP-Symcon.
