Generic Slider
Require: Symcon >= 5.0
Devices of the type Generic Slider can be set to are percentual value. Within Amazon Alexa, the device is interpreted as a common switch and can be used for different devices.
Parameter
| Name | Description |
| Name | Name that is used to address the device via Amazon Alexa |
| Slider Variable | A triggerable variable of type Integer or Float |
Possible Actions
| Action | Description | Possible Sentence for Activation |
| Switch On or Off | Switch the variable towards 100% or 0% | "Alexa, switch <Name> on." |
| Set Value | Switch the variable towards the given value | "Alexa, switch <Name> to 40%." |
Device Search
| Variable | Possible Profiles |
| Slider Variable | ~Intensity.100, ~Intensity.255, ~Intensity.1 |
