Generic Switch
Require: Symcon >= 5.0
Devices of the type Generic Switch can be switched On or Off. Within Amazon Alexa, the device is interpreted as a common switch and can be used for different devices.
Parameter
| Name | Description |
| Name | Name that is used to address the device via Amazon Alexa |
| Switch Variable | A triggerable variable of type Boolean |
Possible Actions
| Action | Description | Possible Sentence for Activation |
| Switch On or Off | Trigger the variable to True or False | "Alexa, switch <Name> on." |
Device Search
| Variable | Possible Profiles |
| Switch Variable | ~Switch |
