Light (Color)
Require: Symcon >= 5.0
Devices of the type Light (Color) describe lamps, that can be switched to any color.
Parameter
Name Description
Name Name that is used to address the device via Amazon Alexa
Color Variable A triggerable Variable of type Integer with the profile ~HexColor, that triggers the color of the light
Possible Actions
Switch On or Off Trigger the variable to white or black "Alexa, switch <Name> on."
Dim Trigger the brightness of the current color to the given value "Alexa, dim <Name> to 40%."
Switch Color Trigger the variable to the given color "Alexa, switch <Name> to red."
Variable Possible Profiles
Color Variable ~HexColor
