Light (Dimmer)
Require: Symcon >= 5.0
Devices of the type Light (Dimmer) describe lamps that can be dimmed.
Parameter
Name Description
Name Name that is used to address the device via Amazon Alexa
Brightness Variable A triggerable variable of type Integer or Float that dims the light
Possible Actions
Switch On or Off Trigger the variable to 100% or 0% "Alexa, switch <Name> on."
Dim Trigger the variable to the given value "Alexa, dim <Name> to 40%."
Variable Possible Profiles
Brightness Variable ~Intensity.100, ~Intensity.255, ~Intensity.1
