Speaker (Muteable)
Require: Symcon >= 5.3
For devices of the type Speaker, the volume can be set. In addition, the device can be muted and unmuted without loosing the configured volume.
Parameter
| Name | Description |
| Name | Name that is used to address the device via Amazon Alexa |
| Volume Variable | A triggerable variable of type Integer or Float that controls the volume (optional) |
| Mute Variable | A triggerable variable of type Boolean, that controls the muting (optional) |
Either the Volume Variable or the Mute Variable needs to be defined
When optional variables are not set, Alexa recognizes that the device does not support the corresponding properties. If optional variables are defined later on, a new search for devices needs to be executed before the newly unlocked functions can be used.
Possible Actions
| Action | Description | Possible Sentence for Activation |
| Set volume | Switch the Volume Variable to the given value | "Alexa, switch the volume of <Name> to 40." |
| Mute or unmute | Switch the Mute Variable to True or False | "Alexa, mute <Name>." |
Device Search
