Temperature Sensor
Require: Symcon >= 5.0
Devices of the type Temperature Sensor measure temperatures.
Parameter
| Name | Description |
| Name | Name that is used to address the device via Amazon Alexa |
| Sensor Variable | A variable of type Float that contains the current temperature in °C |
Possible Actions
Currently, Alexa does not support direct requests to a temperature sensor. Thus, a group needs to be used to request the temperature via voice command. Once the temperature sensor is part of a group, the temperature of that group can be requested.
| Action | Description | Possible Sentence for Activation |
| Request temperature | Request the current temperature of the sensor | "Alexa, what's the temperature of |
Device Search
