Expert Options
Require: Symcon >= 5.0
The Expert Options usually do not need to be adjusted. Handle these options carefully to ensure that the Google Assistant module works as intended.
Options
Name Description
Emulate Status If Emulate Status is active, the module does not wait for the update of switched variables. Instead, it returns the new state based on the triggered value.
Request device update A device update can be requested from Google with this button, synchronizing the configured devices again with Google Assistant. This is usually done automatically when applying changes.
