Generic Switch
Require: Symcon >= 5.0
Devices of the type Generic Switch can be switched On or Off. Within Google Assistant, the device is interpreted as a common switch and can be used for different devices.
Parameter
Name Description
Name Name that is used to address the device via Google Assistant
Switch Variable A triggerable variable of type Boolean
Possible Actions
Switch On or Off Trigger the variable to True or False "Ok Google, switch <Name> on."
Variable Possible Profiles
Switch Variable ~Switch
