Light (Switch)
Require: Symcon >= 5.0
Devices of the type Light (Switch) describe lamps that can be switched on or off.
Parameter
| Name | Description |
| Name | Name that is used to address the device via Google Assistant |
| Variable | A triggerable variable of type Boolean, that switches the light on or off |
Possible Actions
| Action | Description | Possible Sentence for Activation |
| Switch On or Off | Triggers the variable to True or False | "Ok Google, switch <Name> on." |
Device Search
| Variable | Possible Profiles |
| Switch Variable | ~Switch |
