Variable Comparison
Require: Symcon >= 6.0
This module was sponsored by IB-Jaetzel.
The module creates a graph of point clouds based on one or more pairs of variables and a line through the point cloud using simple linear regression. The diagram can be output as SVG or PNG.
feature
- Create a diagram with one or more pairs of values
- Output of the diagram as SVG or PNG
- Output of slope, y-axis intercept, function and coefficient of determination of the graph
Installation
- Via the Module Store install the 'VariableComparison' module.
Set up instances in IP-Symcon
- Under 'Add Instance' the 'VariableComparison' module can be found using the quick filter.
Configuration page
Values:
| name | description |
| X value | Variable selection for the X axis |
| Y value | Variable selection for the Y axis |
| point | Color selection for the point macro |
| Line | Color selection for the line |
| Aggregation Level | Level of how detailed the data is fetched from the archive |
Diagram settings:
| Name | Description |
| Axes small steps | Specifies in which steps small markings should be |
| Axes large steps | Specifies in which steps the marking with labeling is |
| Width | Specifies how wide the diagram is |
| Height | Indicates how high the diagram is |
| Y - Min | Indicates the minimum value on the Y-axis |
| Y - Max | Indicates the maximum value on the Y-axis |
| X - Min | Indicates the minimum value on the X-axis |
| X - Max | Indicates the maximum value on the X-axis |
| Digram Format | Specifies whether the diagram should be output as SVG or PNG |
status variables
| Name | Type | Description |
| Function | string | Specifies the mathematical function of the graph |
| b | Float | Describes the y-axis intercept of the graph |
| m | Float | Describes the slope of the graph |
| Coefficient of determination | Float | Describes how exactly the graph fits the point cloud |
| Start Date | Integer | Date from which the point cloud should start |
| End Date | Integer | Date to which the point cloud goes |
| Chart | String / Media | Returns the chart as PNG or SVG depending on the setting |
