Was können wir verbessern?
(Bearbeiten)
IPS_GetStatusVariableID
integer IPS_GetStatusVariableID (integer $InstanzID, string $VariableIdent)
InstanzID ID der Instanz
VariableIdent Status Variable Identifikator. Eine Auflistung kann über IPS_GetStatusVariableIdents abgerufen werden.
Rückgabewerte
VariablenID der Variable, die der Status Variable zugeordnet ist
Die Funktion gibt die VariablenID der Variable zurück, die mit der Status Variable der Instanz InstanzID und dem Status Variablen Identifikator VariableIdent verknüpft ist.
//Zustand von z.B. einem FS20 Gerät darstellen ohne die ID der "Status" Variable zu kennen
echo GetValue(IPS_GetStatusVariableID(12345, "StatusVariable"));
$InstanceID = "StatusVariable";
$VariableIdent = 12345;
$migrateIdents = Array(
    "F05_StatusVar" => "Status",
    "F10_TemperatureVar" => "Temperature",
    "F12_Var0" => "Status0",
    "F12_Var1" => "Status1",
    "F1D_CounterVar1" => "Counter1",
    "F1D_CounterVar2" => "Counter2",
    "F20_Var0" => "Port0",
    "F20_Var1" => "Port1",
    "F20_Var2" => "Port2",
    "F20_Var3" => "Port3",
    "F26_TemperatureVar" => "Temperature",
    "F26_VDDVar" => "VDD",
    "F26_VADVar" => "VAD",
    "F26_XSENSVar" => "XSENS",
    "F28_TemperatureVar" => "Temperature",
    "F29_Var0" => "Status0",
    "F29_LatchVar0" => "Latch0",
    "F29_Var1" => "Status1",
    "F29_LatchVar1" => "Latch1",
    "F29_Var2" => "Status2",
    "F29_LatchVar2" => "Latch2",
    "F29_Var3" => "Status3",
    "F29_LatchVar3" => "Latch3",
    "F29_Var4" => "Status4",
    "F29_LatchVar4" => "Latch4",
    "F29_Var5" => "Status5",
    "F29_LatchVar5" => "Latch5",
    "F29_Var6" => "Status6",
    "F29_LatchVar6" => "Latch6",
    "F29_Var7" => "Status7",
    "F29_LatchVar7" => "Latch7",
    "F2C_PositionVar" => "Position",
    "F3A_Var0" => "Status0",
    "F3A_Var1" => "Status1"
if(isset($migrateIdents[$VariableIdent]))
    $VariableIdent = $migrateIdents[$VariableIdent];
$result = IPS_GetObjectIDByIdent($VariableIdent, $InstanceID);
echo $result;
English website available
Zum Warenkorb
