IPS_GetOptionList
array IPS_GetOptionList ()
An array of strings with the names of all special switches. The order of the entries is not guaranteed.
This function is intended for internal use only and may change or be removed at any time without notice.
The function returns the names of all special switches that are used by the installed version of IP-Symcon. Options that are only left in the settings (e.g. from older versions) are not included.
The values of the individual options can be queried with IPS_GetOption or IPS_GetOptionEx and changed with IPS_SetOption.
foreach (IPS_GetOptionList() as $option) {
echo $option . " = " . var_export(IPS_GetOption($option), true) . "\n";
/* e.g. returns:
ArchiveCommitInterval = 60
ArchiveRecordLimit = 10000
ArchiveWatch = false
BackupCount = 25
etc. ...
