Core Instances
Archive ControlFunktionen zur Verwaltung des Datenloggings
AC_AddLoggedValuesadds further data records to a logged variable
AC_ChangeVariableIDmigrates the data of a variable into a variable that has not yet been logged
AC_DeleteVariableDatadeletes all data records of a logged variable in a certain period of time
AC_GetAggregatedValuesgets aggregated data from the archive
AC_GetAggregationTypeindicates the aggregation type of a variable
AC_GetAggregationVariablesreturns an array of all logged variables
AC_GetCompactionreturns the compaction entries of a variable
AC_GetCounterIgnoreZerosgets the status whether zeros and negative values are ignored
AC_GetGraphStatusasks whether a variable is being visualized
AC_GetLoggedValuesgets raw data from the Archive Control
AC_GetLoggingStatusasks whether a variable is logged
AC_ReAggregateVariablestarts the re-aggregation of a variable
AC_SetAggregationTypesets the aggregation type of a variable
AC_SetCompactionConfigures the compression of the variable
AC_SetCounterIgnoreZerossets the status whether zeros and negative values are ignored
AC_SetGraphStatussets the property for the visualization of a variable
AC_SetLoggingStatussets the property for logging a variable
Data Format
Permission ControlUser management and synchronization with LDAP server
Calendar ControlCalendar module
Connect ControlConnection module used to enable a secure connection from the outside
Cutter
Cutter_ClearBufferclears the buffer of the cutter instance
DNS-SD Controlmanages established Bonjour services
ZC_QueryServicerequests information from a single service
ZC_QueryServiceTyperequests information from services of a certain type
ZC_QueryServiceTypesQueries all the services that have been set up
Event ControlModule to start scripts on set events
Location Controlcalculates twilight times based on latitude and longitude
Module Controlmanages external and added PHP modules
Notification Controla module for sending push notifications
Presence ControlFunctions for detecting presence within an area
PC_Entersets presence to true
PC_Leavesets presence to false
RegisterVariableRegisterVariablen dienen als eine Datenweiterleitungs- und -verarbeitungsschnittstelle
RegVar_GetBufferliest den internen Puffer
RegVar_SendEventsends an event to the parent HID instance
RegVar_SendPacketsends a data packet to the specified IP address
RegVar_SendTextsendet Daten an die übergeordnete Instanz
RegVar_SetBuffersetzt den internen Puffer
Skin Controlmanages external and uploaded skins
SSDP Controlenables the search for UPnP devices
YC_SearchDevicessends a request to the local network
System InformationFunktionen zum Abfragen von Systeminformationen und -hardware
Sys_GetBatterydisplays information about the battery
Sys_GetCPUInfozeigt die CPU Auslastung an
Sys_GetHardDiskInfozeigt den Festplattenspeicherplatz/-verbrauch an
Sys_GetMemoryInfozeigt den Speicherverbrauch an
Sys_GetNetworkInfozeigt Informationen zu den Netzwerkadaptern
Sys_GetProcessInfolistet alle Prozesse auf
Sys_GetSpoolerdisplays information about the printer queues
Sys_GetURLContentreads the content from an URL as String
Sys_GetURLContentExReads the contents of the __URL__ and returns it as a return value. Here, some __Parameter__ for timeouts, authentication and proxy are made. -
Sys_Pingsendet einen Ping an ein Netzwerkgerät
Tailscale VPNExports aggregated values of a variable as a CSV file in a ZIP archive
TextParserprovides text snippets from websites/files
Translation Control
Util Controldient als Schnittstelle mit erweiterten Funktionen zwischen dem IP-Symcon Dienst und der Verwaltungskonsole
WebHook ControlModule for calling scripts via browser
WC_PushMessagesends a WebSocket message to all connected clients
WC_PushMessageExsends a WebSocket message to a specific client
WebServerModule which makes the Visualization accessible via port
