Consumption per Category
Require: Symcon >= 6.3
Calculates consumption in percent per freely selectable category according to specified start and end dates. The calculation is based on daily aggregation.
function scope
- Selection of multiple variables
- Free text for category
software installation
- Install the 'Consumption per category' module via the Module Store.
Instance setup in IP-Symcon
Under 'Add instance' the 'Consumption per category' module can be found using the quick filter.
Configuration page:
| Name | Description |
| Interval | Interval in which the calculation is executed. 0 = Disabled |
| Sources | List of variables and categories |
status variables
Status variables
| Name | Type | Description |
| Category | Float | A variable is created per category, in which the percentage consumption is displayed. The category name is internally reduced to A-Z, a-z, 0-9 and _ (underscore). This means that the category "Test" and "Test €" will also be categorized to "Test". |
| Start time | Integer | Date from when the calculation should start |
| End time | Integer | Date until when the calculation should go |
