Consumption within Timespan
Require: Symcon >= 4.2
function scope
- Calculates consumption for a time span based on the aggregation of the selected source variable.
- When the time span is changed, the consumption is recalculated
- Different detail lines for start and end date
- Adjustable interval for updating the calculation
software installation
- Install the module 'Consumption within Timespan' via the Module Store.
Set up instances in IP-Symcon
- Under "Add instance" the 'Consumption within Timespan' module can be found using the quick filter.
Configuration Page:
| name | description |
| Source | Source variable to be used for consumption |
| Level of Detail | Determines how precisely the start and end time can be set (date, time, date/time) |
| Use interval to update | If active, an interval will be used to update the calculation |
| Interval | The interval in minutes at which the calculation will be updated |
If the date is selected in level of detail, the start date with the time 00:00 and the end date with the time 23:59:59 is used.
status variables
Status variables
| Name | Type | Description |
| Start | Integer | Start date/start time for consumption (seconds are ignored) |
| End | Integer | End date/end time for consumption (seconds are ignored) |
| Consumption | Float | Consumption between start and end date |
