Meter Overflow
Require: Symcon >= 4.2
The module represents overflowing counters as continuous counters.
function scope
- Calculates the total value of a variable and counts it up even though the device has an overflow.
Software installation
- Install the 'Meter Overflow' module via the Module Store.
Set up instances in IP-Symcon
- Under "Add Instance", the 'Meter Overflow' module can be found using the quick filter.
Configuration Page:
| name | description |
| Source | Source variable to be used for the calculation. |
| Maximum value | From which value an overflow takes place. The maximum value which the device will count. |
status variables
Status variables
| name | type | description |
| Counter | Float | Continuously incrementing value. |
