Reading (Day)
Require: Symcon >= 4.2
The module allows to select a date and then displays the respective (First/Last) counter value of that day.
Function scope
- When the date is changed, the First/Last read counter value of the logged variable is output, depending on the value selection.
Software installation
- Via the Module Store install the module 'Reading (Day)'.
Set up instances in IP-Symcon
- Under "Add Instance", the 'Reading (Day)' module can be found using the quick filter.
Configuration Page:
| name | description |
| Source | Source variable to be used as data source. |
| Value | First/Last value of the day. |
status variables
Statusvariables
| Name | Type | Description |
| Counter value | integer/float | Value for the selected date. |
Visualization
The Visualization is used to display the variable. A date can be selected for which the counter reading (first/last of the day) will be displayed.
