AC_DeleteVariableData
Require: Symcon >= 3.0
int AC_DeleteVariableData (int $InstanceID, int $VariableID, int $StartTime, int $EndTime)
| InstanceID | ID for the archive |
| VariableID | ID of the variable in which the data records are to be deleted |
| StartTime | Date/time as Unix Timestamp (0 = from the beginning) |
| EndTime | Date/time as Unix Timestamp (0 = until now) |
Returns the number of deleted records
This function deletes all logged data records of the variable with the ID VariableID in the period from start time up to and including end time. If the start time and the end time = 0, the logging of the variable is also deactivated.
If data records are to be deleted at a single point in time, the end time must be set equal to the start time
It should be noted that the Unix Timestamp is based on UTC+0. Many European countries have summer time (CEST/UTC+2) and winter time (CET/UTC+1).
After execution, the aggregation of the variable is invalid and must first be re-aggregated. AC_ReaggregateVariable can be used for this.
If the parameters start and end time = 0, the data records of the variable are completely deleted.
// Deletes all data of the variable "TestVariable" in the period 07.10.2015 16:00 UTC+2(CEST) to 07.10.2015 17:00 UTC+2(CEST)
AC_DeleteVariableData(12345 /*[Archive]*/, 45678 /*[Variable]*/, 1444226400, 1444237200);
// Deletes all data of the variable "TestVariable" in the period 07.10.2015 16:00 UTC+2(CEST) until now
AC_DeleteVariableData(12345 /*[Archive]*/, 45678 /*[Variable]*/, 1444226400, 0);
// Delete completely and remove from the Archive Control
// Deletes all data of the variable and deactivates the variable in the Archive Control
AC_DeleteVariableData(12345 /*[Archive]*/, 45678 /*[TestVariable]*/, 0, 0);
