AC_GetCompaction
Require: Symcon >= 6.3
 array AC_GetCompaction (int $InstanceID, int $VariableID)
ID for the archive
VariableID
An array containing the compaction entries of the variable.
Each entry contains the following fields:
Field Type Description
MonthOffset int Month offset for the compaction
CompactionType int Type of compaction (see below)
Compaction Types
CompactionType Description
0 Compact to one value per minute
1 Compact to one value per 5 minutes
2 Compact to one value per hour
3 Compact to one value per day
4 Compact to one value per week
5 Compact to one value per month
6 Compact to one value per year
7 Delete values
This function queries the compaction entries of the variable with the ID VariableID and returns them as an array. Each entry in the array represents a configured compaction with the corresponding month offset and compaction type.
// Query the compaction entries for "TestVariable"
$compaction = AC_GetCompaction(39147 /*[Archive]*/, 53716 /*[TestVariable]*/);
print_r($compaction);
/* Sample output:
Array
    [0] => Array
            [MonthOffset] => -1
            [CompactionType] => 1
    [1] => Array
            [MonthOffset] => 3
            [CompactionType] => 2
