AC_GetLoggingStatus
Require: Symcon >= 3.0
 boolean AC_GetLoggingStatus (int $InstanceID, int $VariableID)
ID for the archive
VariableID
True if logging is active for the variable, otherwise False
This function queries whether the variable with the ID VariableID is logged.
// Query the variable "TestVariable"
var_dump(AC_GetLoggingStatus(39147 /*[Archive]*/, 53716 /*[TestVariable]*/));
echo AC_GetLoggingStatus(39147 /*[Archive]*/, 53716 /*[TestVariable]*/);
/* Sample output
var_dump:
  bool(true)
echo:
  1
