AC_SetGraphStatus
Require: Symcon >= 3.0
 boolean AC_SetGraphStatus (int $InstanceID, int $VariableID, boolean $Active)
ID for the archive
VariableID
Active
True if the display of the variable is to be activated in the visualization, otherwise False.
This function changes the property for visualizing the variable with the ID VariableID to Active.
// Sets the property of the "test variable" for visualization to true
AC_SetGraphStatus(39147 /*[Archive]*/, 53716 /*[TestVariable]*/, true);
