Sys_GetURLContentEx
string Sys_GetURLContentEx (string $URL, array $Parameter)
| URL | Complete URL |
| Parameter | Array with index => value pairs
If the command was executed successfully, it returns the result of the website contents (including binary code), otherwise FALSE.
Reads the contents of the URL and returns it as a return value. Here, some Parameter for timeouts, authentication and proxy are made.
echo Sys_GetURLContentEx("http://www.google.de", Array("AuthUser"=> "test", "AuthPass"=> "test"));
