Dew Point Temperature Calculation
Calculation of the dew point with the relative humidity and room temperature.
The calculation is based on the formulas from the page Wetterochs.
function scope
- Calculation of dew point temperature
- Calculation of the temperature above which the risk of mold growth increases
Software installation
- Install the 'DewPointCalculation' module via the Module Store.
Under 'Add Instance' the 'DewPointCalculation' module can be found using the quick filter.
Configuration page:
| name | description |
| Room temperature | Temperature prevailing in the room in °C |
| Humidity | Relative humidity, which prevails |
status variables
Status variables
| Name | Type | Description |
| dew point | float | temperature, when falling below, excess water vapor will turn into water |
| temperature for risk of mold | float | temperature, when falling below this increases the risk of mold growth |
| Alarm for mold risk | boolean | Alarm, which is triggered when the temperature falls below the temperature for mold risk. It will be turned off when the room temperature is 1°C above the mold risk temperature. |
