Group Control
Require: Symcon >= 5.0
With the help of the 'Group Control', variables can be switched together in groups.
function scope
  • When one variable in the group is switched, all remaining variables in the group are switched as well
  • All variables that are added to a list can be switched with a separate variable at the same time
Software installation
Under 'Add Instance' the 'Group Control' module can be found using the quick filter. - More information about adding instances in the Instances documentation
Configuration Page:
Name Description
Variables The variables present in this list belong to the group; All variables must be of the same type and have the same profile and an action
status variables
Status variables
Name Type Description
Status variant Displays the status of the current group
Visualization
This displays the status variable that can switch the group.
