IPS_HasPermission
bool IPS_HasPermission (int $ObjectID, string $Operation)
| ObjectID | ID of the object to be checked |
| Operation | Name of the registered operation, e.g. VISUALIZATION |
If the currently logged in user has the permission, TRUE is returned, otherwise FALSE.
The function checks whether the user in whose context the current execution runs (see IPS_GetLoggedInUser) may perform the Operation on the object ObjectID. The permissions of the user and the permissions of all the user's roles are taken into account. It corresponds to IPS_UserHasPermission for the current user.
The check is performed in this order: If the operation is not registered, the function fails with "Cannot verify unsupported operation"; if the object does not exist, with "Object #… does not exist". The @admin user always has all permissions, the @unknown user never has any. For all other users: If the user does not exist, the function fails with "User with name '…' does not exist". If the user has the @admin role, TRUE is returned. Otherwise TRUE is returned if a permission of the user or of one of the user's roles grants the operation on the object.
A recursive permission applies to the object itself and to all objects below it in the object tree (children, grandchildren, etc.). A recursive permission on the root object (ID 0) therefore applies to all objects. A non-recursive permission applies to exactly this object only. Links are not followed; only the position of the checked object in the object tree matters.
Operations are registered by modules. Currently the visualization registers the operation VISUALIZATION (access to a visualization with all its objects) as soon as a visualization instance (e.g. Tile Visualization or WebFront Visualization) exists. It is checked against the ID of the visualization instance. The operation name is case-sensitive. If the operation is not registered, the function fails with "Cannot verify unsupported operation".
The function does not require the RBAC feature in the license.
$VisuID = 12345; // ID of a tile visualization
if (IPS_HasPermission($VisuID, 'VISUALIZATION')) {
echo 'Access granted';
