IPS_GetTraceList
array IPS_GetTraceList (int $TraceID)
| TraceID | ID of the trace entry |
An array of trace entries, starting with the entry TraceID, followed by its parent entry and so on up to the start of the chain. Each entry contains the following information as key => value pairs:
| TraceID | integer | Unique, ascending ID of the entry |
| ParentID | integer | ID of the entry that caused this entry (0 = start of a chain) |
| ChildIDs | array | IDs of the entries caused by this entry |
| Depth | integer | Position in the chain, starting at 1 (0 = placeholder for an entry that is no longer available) |
| ObjectID | integer | ID of the object the entry belongs to (1 = no object, e.g. for WebServer) |
| Sender | string | Kind of entry (see sender table) |
| ExecutionUser | string | User on whose behalf it was executed (e.g. @admin; @unknown if no user was logged in) |
| TimeStamp | integer | Unix timestamp of the creation |
| Data | array | Additional information as key => value pairs, depending on the sender (see sender table) |
Sender table
| Sender | Description | ObjectID | Data |
| Variable | A value was written to a variable (even without a change) | Variable | VariableID, Value, OldValue |
| RequestAction | The action of a variable was requested | Variable | VariableID, ActionID, Value, Sender |
| RequestAction | The RequestAction function of an instance was called for a status variable | Instance | Ident, Value |
| TriggerEvent | A triggered event runs its action | Event | EventID, ActionID, Environment, Trigger, VariableID, Value |
| CyclicEvent | A cyclic event runs its action | Event | EventID, ActionID, Environment |
| Script | A script is executed | Script | Sender, ScriptID, FilePath, SenderID |
| Event | PHP code is executed on behalf of an event | Event | Sender, ScriptID, FilePath, SenderID |
| Instance | PHP code is executed for a target object | Target object | Sender, ScriptID, FilePath, SenderID |
| Timer | A timer of an instance is executed | Instance | TimerName, Instance, RunOnce |
| DataFlow | An instance receives data through the data flow | Receiving instance | InstanceID, ParentID |
| WebServer | A request to the WebServer (file/hook) or a JSON-RPC call | 1 | Path or Method, RemoteIP, ProxyIPs (only behind proxies) |
| System | Placeholder for an entry that is no longer available | 1 | Reason |
In traces the kernel records what caused what: every entry represents one operation – e.g. writing a variable, the event triggered by it, its action or script, a RequestAction, a timer or a request to the WebServer – and refers to the entry that caused it via ParentID and to the entries it caused itself via ChildIDs. For every cause this results in a tree that shows, for example, why a variable has changed.
The function returns the entry TraceID and all entries that caused it: the first element is the entry itself, the last element is the start of the chain (ParentID 0). The entries caused by an entry are listed in ChildIDs and can also be retrieved with this function. The IDs of the entries of an object are returned by IPS_GetTraceIDList.
If an entry of the chain is no longer available, the list ends with a placeholder: Depth 0, Sender "System", ObjectID 1 and the reason in Data → Reason. If there is no entry with the ID TraceID, the function fails with "No trace with ID … found".
Traces are only kept in memory and are lost on a restart. The last 25 entries are kept per object, and the last 1000 entries in total for entries without an object (e.g. WebServer). An older entry is kept as long as a kept entry still descends from it, so chains stay complete. When an object is deleted, its entries are removed. Strings in Data are shortened to 100 bytes and marked with "...".
print_r(IPS_GetTraceList(1));
/* e.g. returns:
Array
[0] => Array
[ChildIDs] => Array
[Data] => Array
[OldValue] => 0
[Value] => 5
[VariableID] => 10018
[Depth] => 1
[ExecutionUser] => @admin
[ObjectID] => 10018
[ParentID] => 0
[Sender] => Variable
[TimeStamp] => 1700000000
[TraceID] => 1
// Output the cause chain of the newest entry of a variable
$ids = IPS_GetTraceIDList(10018);
if (count($ids) > 0) {
foreach (IPS_GetTraceList(end($ids)) as $entry) {
echo $entry['Depth'] . ': ' . $entry['Sender'] . ' #' . $entry['ObjectID'] . PHP_EOL;
